borescope for inspecting gas tank during fuel pump replacement?
Old Jun 19, 2018 | 09:23 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Has anybody used a borescope to inspect the inside of the gas tank during fuel pump replacement?
Does enough light get into the tank, when the pump assembly and bung is removed, that you can just as well shine a flashlight, and get a pretty good idea of the condtion of the inside of the tank?
Old Jun 19, 2018 | 09:27 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: borescope for inspecting gas tank during fuel pump replacement?
You don't need a borescope...plenty of room to see in there with a flashlight and a inspection mirror.
Old Jun 19, 2018 | 11:08 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I second.
You just need to look in there for the most part, if there's not a bunch of crap in the bottom you probably don't even need to look in there with a mirror.
I've just used my smart phone to take pictures inside the tank with the flash on.
Old Jun 20, 2018 | 07:41 AM
If you want to use a borescope, nothing wrong with that, most of them have a built-in light. But yeah, with the pump out, you can just kinda look down in there, and see all around inside with a mirror.
BLACK Z
Apr 6, 2018 07:35 AM
IROCME
Apr 20, 2002 05:24 PM
un4givin89
Oct 6, 2001 04:20 PM
