Estimate for intake manifold gasket replacement 700$
Old Jun 21, 2018 | 02:46 PM
Funkman's Avatar
Car: 1988 IROC Z Camaro
Hi,
My 88' IROC Camaro's intake manifold gasket is leaking a bit so I took it to the mechanic and he's saying it'll be about 700$ to fix it with about 5.5 hours of labor involved. Am I being ripped off or is this a fair price? Should I just try to do it myself?
Old Jun 21, 2018 | 02:55 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Estimate for intake manifold gasket replacement 700$
Do it yourself . It’s not that hard of a job.
Old Jun 21, 2018 | 03:13 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Do it yourself.
Old Jun 21, 2018 | 03:18 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Easy job. Take your time and press on. Total upper gasket set is under 40 bucks.
Old Jun 21, 2018 | 03:46 PM
Funkman's Avatar
Thank you, that's what I'm thinking I'm going to do. Does anyone know if the bolts are easy to snap?
Old Jun 21, 2018 | 03:51 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Never snapped an intake manifold bolt.
Old Jun 21, 2018 | 06:14 PM
Funkman's Avatar
Ok, thank you all for the information it may have saved me near 700$
Old Jun 21, 2018 | 10:55 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
bolts wont snap but the intake itself is usually as soft as dogsh!t. Buy the gaskets and a torque wrench, some rtv and look for the torquing order in the manual.
Old Jun 22, 2018 | 07:41 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
While you are in there get a few cans of carb cleaner and clean the crap out of the manifold
Old Jun 28, 2018 | 09:54 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have. And stripped the torx bolts (if TPI)
-- Joe
Old Jun 29, 2018 | 11:14 AM
Funkman's Avatar
OK I'm pretty sure I know all the steps, but I'll have to get some carb cleaner. I do have a TPI so I guess it's likely to strip some of the bolts?
Old Jun 29, 2018 | 01:12 PM
Engine: Lb9
Transmission: M20
They can strip if they are super tight. You might want to invest in a nice t40 socket. look on eBay for a snap-on. i have had to use a chisel to remove a few stripped bolts.
Old Jun 29, 2018 | 02:44 PM
LT1/TA's Avatar
Car: 88 Sport Coupe
Axle/Gears: 4.56
I would warm the engine up before you try to remove the runner bolts,the intake will hold the heat for a while and it will aid in bolt removal.
Old Jun 29, 2018 | 03:07 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
your biggest concern will be stripping out the torx head bolts on the base of the runners. once they're stripped, theres no easy way of accessing them to get them out.
clean all of the crud out of the torx head bolts with a small pick to ensure that the torx head socket seats fully into the fastener. apply firm steady pressure and they will break loose
BobOne
Jun 8, 2013 08:24 PM
MMroc86
Feb 7, 2013 08:14 PM
tsmash
Mar 31, 2012 12:50 AM
MakeitQuick92RS
Jan 17, 2005 09:52 PM
