Larger Oil Pan, w/crossover clearance
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Hey guys I'm looking for a larger Oil Pan, w/crossover clearance that comes with a baffle and possibly a scrapper. I have been looking at this kit, Summit Pan kit
if anyone has feedback or info I'd appreciate it. I looked for info but the word oilpan brings up way to much crap to sort through.
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: Larger Oil Pan, w/crossover clearance
I used that kit on my engine. Seems to work well. I haven't had any issues thus far. The pan is relatively well constructed. While installing my engine, one of the straps I was using broke and so the engine dropped about 4 inches with full weight on the oil pan. Barely a scratch on it.
I didn't have any clearance issues with long tubes, and the K-member hangs down further than this oil pan. It's also nice to be able to run the oil a little lower without worrying about entrainment with the increased capacity.
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Have owned these cars since 82, always had headers, always had a crossover. Right now have a big engine, big crossover pipe, never had an oil temperature problem.
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
I am also curious about the fitment on or cars for the oil pan in question. I tried to search it on here as well and got nowhere. A lot of what I did see were threads about old 2pc rear main seal pans.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Car: 91 z28
Engine: 305 tpi
Transmission: t5
I pm'd Rocket-Doc, the thread starter. He bought that pan, and says that it won't clear the cross over. He's going to dual exhaust, but I have no plans of it. Is there a pan available for third gens with extra capacity and a windage tray that will allow an exhaust crossover with a factory k member?
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Anyone have any experience with these oil pans and a crossover y pipe?
https://www.tpis.com/parts/view/240
https://www.summitracing.com/parts/m...t/model/camaro
5 QUART PANS should work.
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Just ordered a Kevko 2001 1pc rear main pan off ebay. Never heard of this company before, but I saw the name come up while searching and this pan seems to check off all the boxes for what I'm looking for with my available space. Price isn't bad for the pan and pickup, doesn't say anything about stroker clearance but this is a 383 so that might be considered stock stroke for a 400 sbc anyway... I guess I'll see when I get it if it's up to the task and actually good.
https://kevkoracing.com/collections/...nt=34094958542
downsouthboy
Aug 29, 2015 11:29 AM
farm-kid/88camaro
Feb 19, 2002 09:39 PM
