Pushrod length (with pics)
Old Jun 28, 2018 | 08:33 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ignoring the fact that the intake valve seems to have a slightly different pattern than the rest (got me?), it appears every other valve looks like the exhaust valve on this picture.
Looks like the pushrod is too short, as the pattern is wide and sweeps towards the intake.
This is a 7.266" pushrod. What would you increase it to ?
I don't have an adjustable pushrod and don't want to wait a week for one to show up, and then wait another week for more pushrods.
I do have a proform pushrod length tool, the silly plastic thing that slides over the stud and touches the top of the valve, and you measure between the pushrod and the back of the tool. But I can't help but feel like pushrod length is dependent on the rocker used, and it's ratio?
When using the tool, I can fit about a .041" feeler between the ball and the tool. So that would be about 7.307" pushrod. The closest they sell is a 7.300".
-- Joe
Old Jun 28, 2018 | 11:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Pushrod length (with pics)
Pushrod length should always be chosen to give the smallest pattern on the tip of the valve. The smallest pattern is not always on the center of the valve tip. Your exhaust pattern looks very wide so it definitely needs a different length pushrod.
Your measure method with the mockup rocker tool is being done correctly. It may not be 100% exact like using an adjustable pushrod but it should get you close enough. You'll never get a pushrod the exact length so rounding to the closest available pushrod is acceptable.
7.266" seems like a strange length for a pushrod. OEM?
Old Jun 29, 2018 | 01:04 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It was the recommended starting point for retrofit hydraulic rollers according to Howards. (running #91364-16).
Well, I ordered some 7.300", since that's sorta what the proform tool is looking for. I'll give that a whirl.
-- Joe
Old Jun 29, 2018 | 07:29 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Yea they only sell p-rods from on the shelf in 0.050" increments unless you want special order p-rods. My word is close is good enough and the for modest lift cams that plastic measuring tool does the job.
I'm saying you did the right thing here. Please give us some feedback on what you find though.
BTW the adjustable p-rod method is torture to do with the engine in the car.
Old Jun 29, 2018 | 10:19 PM
NoEmissions84TA's Avatar
Nope. Because that checking tool must be used with the camshaft's lobe on the base circle.
It does not care about what brand rocker or it's ratio.
Old Jun 30, 2018 | 10:49 AM
Not necessarily. Depends on how it's measured.
If you take a 7.300" nominal push rod and just measure it with a mic, it very well might come out to that; since the hole in the end makes it slightly shorter. GM specs theirs that way. Aftermarket mfrs however, recognizing that the hole might be different sizes in different mfrs or models or end styles, usually use the "theoretical" overall length that it would be if there were no hole there at all. So a stock spec 7.266" might well be a 7.300" theoretical with .017" off of each end due to the hole, which seems entirely reasonable.
Push rods are available over some size ranges in .025" increments. http://www.texas-speed.com/p-278-tex...50-length.aspx for example.
Personally I find the plastic gauge thing to be UTTERLY USELESS. Mostly because, if the relative locations of its fulcrum (theoretical since it doesn't pivot), its push rod seat, and its tip at the valve, don't EXACTLY match the corresponding dimensions of whatever rockers you're using it with, it will be WRONG; and because, it doesn't take into account the variation in total lift (it "assumes" ... and we all know where THAT leads ... that it's at half-lift, which would be fine if true, but ONE tool can't possibly be exactly half-lift for .450", .500", .600", etc. valve lifts); and because, it doesn't take into account the possibility of variation in the angle of the valves or the studs; and because, it doesn't take into account the ACTUAL ratio of the rockers you are using.
The ONLY truly accurate and reliable method is an adjustable push rod and some light "checking" springs, using the EXACT surrounding hardware that will be installed: the cam, lifters, valves, studs, & rockers.
Alky is exactly right that the correct indicator of correct geometry is the NARROWEST POSSIBLE sweep, since that means that the sweep is exactly centered at half lift (equal distribution of rocker tip arc length on either side of this point). The location of the pattern on the valve stem is TOTALLY irrelevant, within reason. This results in maximum transfer of lobe lift to valve lift, and minimum "scrubbing" of the rocker tip across the valve stem, and therefore minimum side loading and therefore minimum guide wear. The plastic toy thing will NEVER be able to approach the same level of accuracy except by pure dumb luck. Yes it might be "close enough" in some or even "most" situations; but you have no way of knowing that, for YOUR specific hardware combination. You'd be proceeding on the basis of blind faith, not anything resembling "measurement".
Old Jun 30, 2018 | 07:50 PM
Someone does not agree with this.
Old Jul 1, 2018 | 10:40 PM
cardo0's Avatar
Engine: 350 Gen II
Transmission: A4
TraviZ
Dec 21, 2005 12:08 PM
Mkos1980
Jan 20, 2002 08:16 PM
SMasterson
Aug 9, 2001 12:06 PM
jcb999
Jul 31, 2001 08:42 PM
JDMZ28
Dec 18, 2000 09:06 PM
