Short drop window
Old Jul 20, 2018 | 08:23 AM
89ta89's Avatar
Short drop window
I’m trying to finish up restoration of my 89 TA and don’t want to destroy new weatherstripping. Has anybody done short drop windows on their fbody or know of a way or anything... seems to be very little information out there and I think we all have had this issue with our frameless windows.
Old Jul 20, 2018 | 03:29 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Short drop window
Hi 89ta89 ,
For those of us (me) who have no clue what a "short drop window" is , would you please explain exactly what that term means ?
PS , this was a better question for the "Body" subforum rather than the "tech/ General engine" area , maybe a mod can move it there for you .....
Old Jul 20, 2018 | 04:42 PM
89ta89's Avatar
Hey you’re probably right, it’s been a while since I’ve been on here. To my knowledge or findings, short drop window is what it’s called when the window drops down a little bit as the doorhandle is pulled so the window does not rub or pinch on the weatherstripping. Often found a new frameless windows such as convertibles etc.
Old Jul 20, 2018 | 05:07 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
I have seen this feature on a new Mustang vert and it's pretty slick. I have to slam my iroc door, or have the window cracked a tiny amount and then it closes nicely. I have wondered what it would take to add this, but I expect it to be a good chunk of work.
Old Jul 20, 2018 | 05:09 PM
OrangeBird's Avatar
Car: 1989 Firebird
Thank You 89ta89 !
Ok , now I'm gonna show my age
Back in the 1970s I owned a 1960s vintage Lincoln convertible that would drop the two rear door windows a couple of inches when the power top was retracted . Well , usually , that is , at least twice that I recall the relays failed to lower the windows and CRUNCH !!! Two broken windows ! It only took me twice replacing the windows till I no longer trusted the mechanism to lower the windows so I would manually put them all the way down BEFORE I pushed the open button and I never bought another rear door window for it again .
Thank You again for bringing back the memory of my favorite convertible , broken windows notwithstanding .
Old Jul 20, 2018 | 05:13 PM
Drew's Avatar
Well... You'd have to have a switch on the latch to tell the whatever that the door is closed, so it can move the window back up. And you'd have to have a switch on the exterior door handle, or another on the door latch to tell the whatever that it should move the window down so you can open the door. Potentially this second switch could be the same switch as the switch you'd need on the inside handle, again to tell the whatever that it should move the window down so you can open the door.
So three switches added to each door, then you'd have to figure out the whatever to actually go between the switches and the window motor(s). That would probably be the easy part. Making the stock door latches work at all is a bit of a trick. Probably be easiest to adapt the parts from whatever other car that has that feature.
Old Jul 20, 2018 | 06:24 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
The new camaro,challenger and mustang all do it. I wonder if one of those systems would work.
Old Jul 20, 2018 | 06:28 PM
89ta89's Avatar
Thats why I figured nowadays there would be an aftermarket for this common problem!
TKD89RS
Dec 31, 2001 11:55 AM
z28camaro396
Oct 9, 2001 08:58 PM
92TA-Ragtop
Jul 22, 2001 04:46 PM
Stang Eater
Mar 8, 2001 04:09 AM
BlackBird305
Oct 21, 2000 11:11 AM
