Stealth ram hose question
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stealth ram hose question
Looks like heater hose. The other side going from the top down is for the cts.
Is this on a vette ?
Engine: Lb9
Transmission: M20
Coolant temp sensor, looks like you have two holes on the passengers side. I’d put the cts going straight down and the coolant hose in the front.
First I will have to find or buy a cts and then figure out where the plug to it is hiding...
I didn't start this swap, and it's been a real pain figureing out the little details.
Engine: Lb9
Transmission: M20
The cts wires are yellow and black. It’s the same sensor that’s under the plenum the intake air temp sensor.
https://www.rockauto.com/en/catalog/...+/+sensor,4748
The intake air temps sensor should be tan and black. You will have a single lead left over from the egr temp sensor. You should have a chip programmed other wise I would expect a egr code 32.
Engine: Lb9
Transmission: M20
Those were for the air pump diverter valve.
Fronzizzle
Alternative Port EFI Intakes
17
Jan 9, 2012 09:01 PM
mypontiac
May 10, 2003 09:59 PM
onebadta
Dec 2, 2002 01:31 PM
