giving up
Old Jul 31, 2018 | 09:31 PM
SketchyZed's Avatar
Car: 1991 camaro z28
Engine: 5.7
giving up
I gave it my all but now its just becoming too much first the l98 started knocking then the old guy in chrysler hit me started saving up got very close and now my fuel pump went out again i just cant do it anymore.... how much do you think i could get for my car?
Old Jul 31, 2018 | 09:35 PM
Drew's Avatar
Re: giving up
Wrecked and not running, potential rebuild in store? Not a lot. Depends where you're located too... That sucks.
Old Jul 31, 2018 | 09:40 PM
SketchyZed's Avatar
Engine: 5.7
Re: giving up
Mississippi not really any rust anywhere its a real z28 with g92 package has 355 cam and heads are unknown intake is a jegs duel plane and carb is a holley street demon 625cfm
Old Jul 31, 2018 | 09:49 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: giving up
Sorry to hear about your bad luck. Your car will fetch more parted out unfortunately.
Old Jul 31, 2018 | 09:54 PM
SketchyZed's Avatar
Engine: 5.7
Re: giving up
its not a big loss as long as i still have a warranty on that pump im still good im just getting ready for the worse
Old Jul 31, 2018 | 09:55 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: giving up
Did you do the pump yourself?
Old Jul 31, 2018 | 10:03 PM
SketchyZed's Avatar
Engine: 5.7
Re: giving up
nope didn't have the tools or the time
Old Aug 1, 2018 | 03:12 PM
SketchyZed's Avatar
Engine: 5.7
Re: giving up
Good news the tire shop that did the fuel pump it is under warranty so it's all good now no harm done I was just worried I would have to pay to fix it so I was preparing for the worst but I'm on back on track to just fix the 1/4
Old Aug 1, 2018 | 08:57 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: giving up
So now that youre no longer giving up, post picks of the damage to your car, just curious.
Old Aug 1, 2018 | 10:10 PM
SketchyZed's Avatar
Engine: 5.7
Re: giving up
Don't have any pics of my car on the desktop so heres the link to the whole damage https://www.thirdgen.org/forums/body...-accident.html
Old Aug 2, 2018 | 07:44 PM
Vader's Avatar
Re: giving up
The quarter is repairable. Replacing a quarterpanel PROPERLY is not an easy task.
Try to find a quarter to replace this:
There's not much choice but to do it the right way.
EDIT: Incidentally, that was done with NO filler. Lots of stud welding, pulling shrinking, filing, and shaping. Even the bumper got a workover without cracking the chrome.
Old Aug 2, 2018 | 07:53 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: giving up
There's really no filler on that vader? Impressive work getting that panel so straight and the lines correct
Old Aug 2, 2018 | 10:06 PM
SketchyZed's Avatar
Engine: 5.7
Re: giving up
turns out its not my fuel pump that went out but possibly wiring to the pump if it is too expensive i'll just either take out all valuable parts like the built 355 and scrap it and see how much money we get from it or my other side says i could just put a mechanical fuel pump on it and be done
Old Aug 3, 2018 | 12:41 AM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
Re: giving up
Looks Good, bringing back memories Had the same quarter damage.. I gave up a clean '66 Olds F-85 post car years ago before the internet because I couldn't source a non-dented 1/4 and the aftermarket didn't stamp em yet..
Old Aug 3, 2018 | 10:46 PM
SketchyZed's Avatar
Engine: 5.7
Re: giving up
got my car running took it to a shop for a day the shop calls and says they couldn't work on it because the guy who does wiring isn't in today the next day he's there and then they say they don't to electric work so i went up there found my car in a car in a parking spot check down the wiring starting at the fuel pump making my way down to the relay not getting power from there then it hit me the dang switched 12v wire was unplugged i plug it back up and drove off pissed because if i had enough time on monday before work i could have fixed it right there but i was running late so yeah that happened.
Letting my uncle who worked on 80s and 90s wiring back in the day to help re wiring them and undoing that the bad wiring they did when they swapped my engines
Old Aug 5, 2018 | 12:13 PM
SketchyZed's Avatar
Engine: 5.7
Re: giving up
had to redo all the wiring from the carb swap those were so sketchy ***** that did the engine swap for me moral of the story have someone you trust do it or do it yourself
NEOMASTERZ28
Nov 14, 2001 01:47 AM
Monkie
Oct 19, 2001 01:04 PM
Reno
May 28, 2001 10:05 PM
bsnoke
Apr 10, 2001 03:07 PM
BadSS
Oct 12, 2000 10:35 PM
