Identifying a l98 from under the hood?
Old Oct 1, 2018 | 11:10 PM
83' 2.8camaro's Avatar
I bought a 91 grand trans am for cheap a while back as a project. From the moment i drove it i knew some **** was different about this car. It was completley straight piped. It has a 3 speed with a shift kit and ratchet shifter. It was rediculousely loud @ 3k cruising the freeway. Theres a edellbrock carb and manifold where the fi should be. The electric fans have been swapped?? for a mechanical set up. So, I replaced the whole brake system cleaned up the z06 rims put a flowmaster 44 on and got it running pretty well, but i'm curious to know how can i figure out if that's even the l98 350 that the car came with from the factory?
What is the least expensive way to build on this platform? It's a toy to mash in.
Old Oct 1, 2018 | 11:48 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: What 350 do i have?
Post up a picture
Old Oct 2, 2018 | 12:14 AM
Originally Posted by tealman92
Post up a picture
ill take one tomorrow durring the day and post it
Old Oct 2, 2018 | 12:18 AM
Re: Identifying a l98 from under the hood?
Found this in my gallery, this is it.
Old Oct 2, 2018 | 12:21 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looks like a carbed small block chev
L98 have TPI.
Is it a 305 or 350? You'll need to get a casting number or the suffix number off the block since they all look the same on the outside.
Old Oct 2, 2018 | 12:43 AM
Where are the casting numbers located on the block?
Old Oct 2, 2018 | 01:54 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
At the back of the block behind the drivers side head. Kinda hard to see but with a flashlight amd a mirror you can see them. Look for lg 5.7
Old Oct 2, 2018 | 10:58 AM
GeneralDisorder's Avatar
V-belt swap, clutch fan swap, Edelbrock carb swap..... all I see here is fail. They took off really excellent parts and put $hit parts back in their place. Whoever did this should be flogged with those v-belts. Sadly I don't think you will find success under all that fail.
GD
Old Oct 2, 2018 | 11:07 AM
GEN Xer's Avatar
Car: Formula 350
Transmission: A4
With the center bolt valve covers there's a good chance it's an l98, at any rate it's at least an 87 or newer block. Id bet it's the original.
Old Oct 3, 2018 | 12:15 AM
What do you guys recommend i do to it?
i looked for the brain. Its been harvested along with the other stuff. Would it be cheaper to go back to fi or upgrade the carb set up?
Old Oct 3, 2018 | 12:32 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Looking at the pictures someone deleted the smog pump and the ac pump on the left side of the engine. Dont run that motor anymore until you get the altenator mounted correctly. The waterpump,alternator, and ps pump are all still the serpentine system style. You need to remove the manual fan and go back to electric then install the smog pump/ac accessorie mount and install the delete pulleys and put the correct belt and tensioner back on it. Get that sorted then go from there.
Old Oct 3, 2018 | 01:22 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
according to Casey, there is a stamp on passenger side of block, up front, where it meets head. You can see if engine was mated to a Firebird and if it is VIN matching.
Old Oct 4, 2018 | 07:48 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I think you can restore the serp belt system without installing a smog pump or A/C compressor. There is a pulley available to replace the smog pump. I believe there is also one to replace the A/C compressor. You'll have to look for those. You still need the passenger side accessory bracket. Whoever did all this to the L98 must have been afraid of EFI. Sad really. They probably ruined or just tossed all of those parts that are becoming more rare and valuable everyday.
Old Oct 4, 2018 | 08:52 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
At one point I was surprised by things like this but then I realized someone too stupid to use EFI is probably the kind of person who will downgrade the car to make it "oldschool"
Old Oct 5, 2018 | 07:02 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
pretty"Hick"under that hood,but I have seen far worse "hack"jobs on thirds before-this one might actually run pretty decent and strong what would be really funny is to see something like this under the hood of a 4th gen-carb converted,TH350 swap,mech flex fan,chrome P.A.W. air cleaner or "triangle of death" poking out from under that overhanging 4th gen windshield base Back to subject vehicle,isn't that a standard rotation W/P with the fitting on top-turning backwards?
F&Ybodlover
May 8, 2006 12:11 PM
92lt1
Aug 21, 2004 12:05 PM
ChrisFormula355
South West Region
Dec 5, 2003 05:09 PM
u r sofa king we tah did
Oct 6, 2002 01:51 PM
Hulk0202
Aug 16, 2002 05:13 PM
