Throttle Cable...
Old Oct 2, 2018 | 09:50 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Throttle Cable...
I need a new throttle cable, but the parts suppliers list two different lengths for a V-8 thirdgen.
How do I know which one to order?...
Old Oct 2, 2018 | 09:59 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Throttle Cable...
Oh. i don't know, there is a new device called a tape measure, maybe try and measure it.
Old Oct 2, 2018 | 11:32 AM
ULTM8Z's Avatar
I'm not sure why the snarky response... the guy is asking a legitimate question...
any rate... probably is the case that you have one length for TPI and one for TBI (TPI being the longer one).
Old Oct 2, 2018 | 11:47 AM
red rock's Avatar
Car: 1987 iroc
Just a little humor, nothing to get alarmed about. But really, why wouldn't you measure your old one?
Old Oct 2, 2018 | 12:17 PM
T.L.'s Avatar
LOL!!! I knew someone would say that, but....well...I sort of...threw the old one away. I never expected there would be 2 different lengths...
Old Oct 2, 2018 | 12:25 PM
red rock's Avatar
Car: 1987 iroc
Well, that little bit of info would have helped. The TPI cable is longer i believe. So if you have a carb, i would say the shorter one.
Old Oct 2, 2018 | 02:15 PM
T.L.'s Avatar
Well, that little bit of info would have helped. The TPI cable is longer I believe. So if you have a carb, i would say the shorter one.
'Sorry, this is a carbed '83. They didn't have TPI, although some had CFI. My only other GUESS is that maybe one is for cruise control and the other not, but that isn't mentioned in online catalogs. My car does not have cruise control...
Old Oct 2, 2018 | 05:26 PM
red rock's Avatar
Car: 1987 iroc
Can you look at the ends of the cable and see a difference?
Old Oct 3, 2018 | 12:34 PM
T.L.'s Avatar
Interesting that none of the gurus here seem to know why there are 2 different throttle cable lengths for '82-'86 carbed thirdgens...
Old Oct 3, 2018 | 01:08 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I have one for an '85 carb
Old Oct 3, 2018 | 02:08 PM
T.L.'s Avatar
How much $ do you have to have for it?...
Old Oct 4, 2018 | 11:29 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Looks like there are atleast 4 options the 24 is nla.
https://www.thirdgen.org/forums/engi...arburetor.html
zacharyhorn
Carburetors
Apr 12, 2012 08:38 AM
88gunmetalgta
Aug 2, 2011 01:47 PM
Damon
Carburetors
21
Jun 17, 2004 09:22 AM
Drew
Mar 31, 2002 03:08 PM
