86 iroc z28 camaro no power but battery is good!
Old Oct 18, 2018 | 07:19 AM
paul305's Avatar
no power at all battery is good it was running good until i change the ECM i had it tested and they said that the processor was going bad in mine they shipped me a new one I put it in but something was not right it started acting up stalling
both ECM are 1227165 units I put mine back in but now there is no power nothing when you turn the key over not even head lights or dome light when i do get a dome light as soon as i turn the key to start the car everything go's out
HELP Please
does the ECM computer control the power to all the car? or is the ECM fried I disconnected the battery cable before installing the ECM
Old Oct 18, 2018 | 09:10 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 86 iroc z28 camaro no power but battery is good!
Originally Posted by paul305
............ not even head lights or dome light when i do get a dome light as soon as i turn the key to start the car everything goes out.........
This is the classic symptom of a bad connection in one (Or both !) of your battery wires . Either the positive wire is bad where it connects to the battery or starter , or the negative wire is bad where it connects to the battery or engine block . Check both sides of both large battery wires , check also the smaller wire that runs from the battery's negative terminal to the body (radiator support) , and for good measure make sure the ground wires are OK on the back of the cylinder heads .
FYI , the ECM doesn't control anything but the engine , so your lights and all other electrical not working have nothing to do with that . You say you disconnected a battery terminal when you replaced the ECM , good on you , never change an ECM without disconnecting the battery , but that terminal may very well be the one that's now got a bad connection , clean both battery terminals and see if your problem disappears .......
Old Oct 21, 2018 | 08:04 PM
paul305's Avatar
thanks for your help
both wires are connected good I didn't see any burnt wires or fusible links the battery is fully charged but when I turn on the head lights or like radio and dome light all power is gone
Old Oct 21, 2018 | 08:21 PM
Vader's Avatar
Measure battery voltage with a separate voltmeter. With the ignition on, measure at the battery, and at the alternator. reference the meter at the battery negative, and then at a good engine ground. Is anything missing?
Old Oct 21, 2018 | 09:23 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
As Vader said, time to get ***** deep with a multimeter - or if you feel like speeding things up, get a test light, attach it to an earth point and start poking around.
Old May 5, 2019 | 06:00 PM
paul305's Avatar
thankyou I will try that I check for voltage drop and resistance should be 12v at the starter whale cranking the engine right?
paul305
Oct 17, 2018 09:16 PM
Firebird Mess85
Jun 12, 2010 04:52 PM
IfknROC85
May 25, 2010 11:04 AM
92RSsleeper
Jan 13, 2008 12:19 PM
ChrisR
Feb 11, 2001 06:04 PM
