EGR DELETE AND VACUUM HOSE HELP
I have a 1989 camaro 5.7L TPI. I just put headers, cam, cat delete and have a code 32 for egr. I am about to order a custom chip so figured I'd just delete the egr and plug or reroute vacuum hoses where needed.
my question is ..... if I remove the egr and egr solenoid what vacuum lines do I need to reroute or plug off? I know a long hose goes from the canister to the egr solenoid and up to the throttle body and egr. Do I just cap off the line on the throttlebody or reroute a line to it?
Transmission: Pro-built 700R4
Re: EGR DELETE AND VACUUM HOSE HELP
Just change the valve and/or solenoid and be done with the code 32.
EGR is a good thing for engine health - it reduces combustion temps at cruise when it's lean and hot and that improves exhaust valve longevity. There is no performance reasons to delete it. So why not just make it work?
GD
GD
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The code 32 is thrown with the lack of pw of the egr solenoid. In 85-89 tpi the temp sensor can throw a code 32.
when I bought the car there was no light on. I recently installed timing chain, cam, rockers and when I started the egr temp wire was cut. I reattached the wire when I went back together and now light on and code 32 only. I even reached in there and cut the wire again but still code 32
Engine: Lb9
Transmission: M20
https://www.ebay.com/itm/EGR-Tempera...gAAOSwq7JT1wtf
you can have the code 32 programmed out and still retain the egr function or fix the faulty temp sensor.
djmarch
May 15, 2015 04:22 PM
88TransAmFreak
Jun 2, 2009 09:34 PM
Homer
Aug 13, 2002 01:48 PM
