Any ideas why rpm tach goes nuts, car instantly dies?
I bought the car recently..bought a new battery, changed the spark plugs/wires, oil change, new oil filter and drained the fuel. Added new fuel. Car see's 45psi on fuel pressure.. When I was under the car I noticed the cats gone and the metal line that ties into the cats is cut and pinched/crimped at end. The car fires over easy..but rpm hiccups and it dies or it just dies immediately or after running 5 mins.. any help is appreciated.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Any ideas why rpm tach goes nuts, car instantly dies?
Tpi ? 3.1l ?
Does it fire back up after it dies ?
If not what are you missing, injector pulse , spark ?
90 iroc z 305 5.0.. tpi.. fires right back up.. but sometimes dies right away immediately.. sometimes tach goes haywire.. stumbles.. then keeps idling or dies
Car: '89 Firebird
Engine: 7.0L
I think the tach is operated by the ignition coil, so if the coil goes haywire then maybe the tach would too and the engine would die. Uneducated guess.... I'm no mechanic so don't take my words too seriously.
Yeah suspect ignition module inside the distributor, or coil. Check the coil with a meter, if it's alright check out the ignition module.
GD
GD
Ok thanks I'll take a look into it.. i.drove it for the first time today.. and it died and I had to crank it maybe 10 times before it would fire back up..
I replaced the distributor cap and rotor, ignition control module and ignition coil.. car fired right up.. I drove it 2 miles.. died pulling up to a stoplight.. wouldn't start.. just turn over but not fire.. I'm lost.. fuel pump? Timing? Idk about to save up and take it to a shop.. I'm out of ideas/patience
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Common problem in boats. A bad tack will kill the ignition. Disconnect the tach
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Yup
bad pickup coil in the dist will cause the tach to bounce as it misfires and fails.
