My carv will not start.
Subscribe
Dec 2, 2018 | 08:07 PM
91' V6, No SES, VATS pops up for second, what is happening???
Reply 0
Dec 2, 2018 | 08:30 PM
Re: My carv will not start.
What are you missing, fuel pressure, spark & injector pulse.
Reply 0
Dec 2, 2018 | 08:59 PM
Car was running well, until I get home and then 10 minutes later, I tried to head out and all I get is No SES, The VATS lights up for a second then I turn the key and nothing, the fuel pump does prime, but no crank, not sure what to do*
Reply 0
Dec 2, 2018 | 09:16 PM
Check your battery. And especially the connections to it.
Reply 0
Dec 2, 2018 | 09:18 PM
Is your car an auto or manual?
Reply 0
Dec 2, 2018 | 09:41 PM
Auto, I am charging the battery now, will see if it starts tomorrow?
Reply 0
Dec 2, 2018 | 10:08 PM
http://www.austinthirdgen.org/mkport...nT_starter.jpg
the easiest spot to check to see if it’s the vats killing the starter enable relay is at the relay itself.
the relay is under the drivers side kick panel.
Reply 0
Dec 2, 2018 | 10:21 PM
Always best to start troubleshooting with a full batt.
And yeah if it still doesn't crank jumper out the starter enable relay and if it cranks..... you have a VATS issue. If it still doesn't crank you have other problems such as battery cable, starter, ignition switch, etc.
GD
Reply 0
Dec 3, 2018 | 02:01 AM
Charged up the battery, still no Crank, so what can I do next?
Reply 0
Dec 3, 2018 | 05:44 AM
On your starter you will have a small wire terminal. Connect a 12 vdc test light to it, other side to ground, turn ignition switch to start. If test light turns on, ignition switch and circuit is good. Next, with ignition off, jump the 2 large terminals of the starter with either a screw driver or a large jumper wire. The engine should crank over but not start. If it does not crank over, starter or starter relay is bad.
Reply 0
Dec 3, 2018 | 04:35 PM
Alrighty then, I found a video on Youtube, how to solve my little problem, it was the stupid re;ay in the driverside kick panel, i simply swapped it for a single bypass wire and it starts, thanks guys*
Reply 0
Dec 3, 2018 | 04:52 PM
Yep that's the starter enable relay. Happens all the time to these.
GD
Reply 0
Dec 3, 2018 | 05:04 PM
Yup!...been hearing about them for years, my Deceased Uncle was suppose to get me a 88' but was late getting back to me and I ended with a 91'!...but thats okay, I have learned to rework a few things with it*
Reply 0
Subscribe
