What am I missing?! V6
Old Dec 4, 2018 | 10:03 PM
lcmchefslife's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1L V6
Transmission: Automatic
am stumped. Stopping for the day to regroup. Just need outside help.
Was driving, came to a red light and engine died (no check light came on). Tried to restart and engine would crank but not start. Got the car home via tow. And the initial tests began. Came to find no spark at spark plugs. Time to pull out the repair manual. Started my way down Chart C-4A. Ended up replacing the Ignition Coil, The Module, The Pick-Up Coil, Distributor Cap and Rotor (all were old or used parts I had put in) finally made it all the way down the diagram, still with no spark. So checked the spark plug wires for resistance, they were still good. Checked Fuses, good. Checked Codes, just 12. So I checked the resitance from Aldl Connector 'M' to ECM harness, no breaks. Then went through and checked Volts at ECM harness, all matched up besides: Bypass BC7 (7.3v instead of 0), EST BC8 (6.6v instead of 0), Reference BD8 (10.3v instead of 0), and Reference Low BD9 (10.6v instead of 0). Pulled out wiring diagram, found all wires were from Module to ECM. Thought maybe the resistors in ECM werent closing so I replaced the ECM. Still no Spark, but will crank. Going to recheck volts at ECM in the morning out of curiousity. But now i'm stumped and would like some outside feedback. Any ideas? What am I missing?
Old Dec 4, 2018 | 11:11 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: What am I missing?! V6
Where is the last place you have spark? From the coil to the distributor or the distributor to the wires?
Old Dec 5, 2018 | 12:36 AM
Engine: 3.1L V6
No where. Have no spark anywhere.
Old Dec 6, 2018 | 11:02 AM
GeneralDisorder's Avatar
Often when you get higher voltage than you should it's because of a bad ground. Check all your ground points.
GD
Old Dec 6, 2018 | 02:39 PM
Drew's Avatar
About two cylinders.
Badum tiss. Been holding this one in for DAYS. Sorry.
Old Dec 7, 2018 | 04:45 PM
atikovi's Avatar
Any security system on the car? And how are you checking for spark?
DanielRicany
Feb 19, 2018 07:33 AM
Malicious3rdgen
Oct 28, 2013 01:43 AM
soulbounder
Aftermarket Product Review
Sep 25, 2001 12:27 PM
91DropTopTA
Apr 18, 2001 11:41 PM
Zoxo
Carburetors
Sep 15, 2000 12:41 PM
