bogging/ stalling/ high idle
Old Feb 5, 2019 | 04:31 PM
lichowid91's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
I have a 90 RS 305 TBI car runs fine for about thirty minutes then starts to bog at random intervals even while accelerating sometimes if I feather the gas I can keep it going. If I let it sit for a while it will run fine again for a while even with the engine temp at operating temp. I'm thinking it may be the fuel pump; is it possible that the pump is running hot and starts to fail until I shut the car off for a bit?
Old Feb 5, 2019 | 05:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: bogging/ stalling/ high idle
You can check fuel pressure to illuminate the pump. It could also be the ignition control module in the distributor they commonly fail when heated up.
Old Feb 5, 2019 | 05:11 PM
lichowid91's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
I guess I should start with getting a fuel pressure valve (T bar valve I think) hook it between the TBI and fuel line right?
Old Feb 5, 2019 | 05:18 PM
Engine: Lb9
Transmission: M20
Correct , some testers allow you to place where the fuel filter goes. Drivers side rear frame rail. I think tbi fuel pressure is 10-12psi.
Old Feb 9, 2019 | 05:05 PM
lichowid91's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
I went ahead and tested it it stayed at 11 PSI, but it wasn't bogging at this point I have to drive it around for a bit before it will bog. On another note I was doing some research into the charcoal canister/ vapor canister and am focusing on that a bit because that sounds like that could be my issue as well. I can't find that much information on them nor do I really understand how it works. Anyways I have the enclosed canister I think from 89 and up does anyone know how to tell if those go bad or if there's a way to reuse it since it doesn't have a reusable filter?
middian
Carburetors
19
Jan 28, 2016 08:00 PM
Zach/90\irocZ
Mar 13, 2012 08:15 AM
92 Rally
Jan 26, 2010 01:33 PM
Skatepunk60
Feb 5, 2006 04:02 PM
Dapht Punk
Aug 7, 2005 03:25 PM
