Stall at start
Old Feb 8, 2019 | 06:38 PM
PD74's Avatar
Car: 1989 IROC Camaro
Engine: 5.7 TPI with Vortech Supercharger
Stall at start
I have read multiple posts on the topic, but still can't seem to figure this out. The car is a 1989 IROC 5.7 TPI, with the corvette ZZ4 heads, Vortech V1 supercharger, Vortech/MSD BTM box, and headers. It still has the stock, plenum, runners, cam, and injectors. I can send my Tuner Pro file if anyone wants to take a look and see if they see anything. The car starts fine, but dies as soon as it starts. If I feather the gas it will stay running. When I hit the gas it revs great, with no hesitation. Fuel pressure prior to start is right at 50 psi, when I can get someone to look while I keep it running it rides at about 42. I have rebuilt the top end with all new gaskets. I have replaced the IAC valve. I have even removed the supercharger and MSD box to ensure they were not causing the issue. I am not getting any CEL and according to the Tuner Pro all my sensor are operating properly. My TPS is riding right at .57 volts. I did a smoke test looking for vacuum leaks and didn't find any. Tuner Pro tells me my BLM is 160, so in my head it is screaming a fuel issue, but I can't seem to find it. If anyone has a clue it would be greatly appreciated.
Thanks,
Phil
Old Feb 8, 2019 | 06:47 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stall at start
Have you tried adding fuel cold start enrichment, crank paw vs coolant temp?
rubbermanZ28
Aug 17, 2003 08:01 AM
ChrisFormula355
Aug 7, 2002 08:02 AM
burnoutrpm
Jun 18, 2002 11:56 PM
OutlawFormula
Feb 23, 2001 10:51 AM
