Identify a cam by the casting marks
added I bought a project car and trying to figure out what cam is in it. It is a new 383 stroker motor with Chevy performance parts. The cam has 586 WB15 and 190 98R stamped on the end. Can anyone confirm what cam this is? I am trying to figure out what torque converter stall I need.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Identify a cam by the casting marks
The R probably means a roller cam. Were there roller lifters on the cam?
586 is the last part of GM's part number for an LT4 Hot Cam. Lobe lift should be 0.328. Duration at 0.050 should be 218/228
A vernier caliper and a dial gauge can tell you the grind when installed in an engine with a degree wheel on it. You can use them to determine lobe lift and duration.
Without knowing where the engine makes torque, converter stall selection is a guess. The same cam in a 383 and a 350 will make torque at different rpms.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If this is a hot cam woulnt the timing chain dowel pin be cut ?
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
The picture shows the "Roller" rocker arms. Alky is asking about the lifters themselves. You need to put the intake manifold and see if there is a "Spider" bracket the holds the lifters or not.
Also, is that a crack between the two valve springs in the picture?
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
snap a pic of the other end and i can tell you if its a roller cam straight off the bat
impaled
Jan 28, 2009 03:20 PM
