Smog and a/c removal
Car: 91 Z28
Engine: 5.7
I removed my smog pump and air conditioning system. Now I have the brackets that look so ugly. What are my options to remove them? Do they sell kits to replace and make it look a lot cleaner?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Smog and a/c removal
You can buy the delete pulleys
Dorman 34157 Air Conditioner Bypass Pulley
there are 2 different styles gm 10186167 with a large 6 grove pulley or gm 10129569
https://www.summitracing.com/parts/ADO-10186167
Engine: Lb9
Transmission: M20
How’s the flat idler working for keeping the belt on. Just curious
Car: 91 Z28
Engine: 5.7
Car: 91 Z28
Engine: 5.7
Car: 91 Z28
Engine: 5.7
Car: 91 Z28
Engine: 5.7
https://marchperformance.com/chevy/c...unt-ultra.html
Hay Pauline I done the same as you on my87 iroc 5.7 tpi about 10 years ago.
What belt size or part number did you use .I have an 88 iroc now with the smog delete but now want to ditch the AC but cant remember the belt details I used.
I hope you can help me out.
321GO!
Feb 2, 2018 09:27 PM
