1986 camaro Failed smog.Help
Re: 1986 camaro Failed smog.Help
No error codes present. Just picked up EGR. Anything else I have to do besides replacing the part?
No clues as where to start on evap.
Shop gave me an estimate from 500-1000$ so I want to at least try to fix egr and vacuum problems to lower cost
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You should stick to one thread.
https://www.thirdgen.org/forums/tpi/...-i-need-2.html
Car: 1992 Z28
Engine: 383
What engine do you have? Is this the California test? The evap test is pressuring your fuel tank and clamping the hose by the charcoal canister. So you need to find your leak between your charcoal canister and fuel filler. Usually a crack in the filler neck, oring on top of fuel tank, purge vent valve leak or hose cracks between fuel tank and canister. Easy to find just takes time.
Trick414
Jun 25, 2008 01:17 AM
