Fuse beside battery.
Old Apr 2, 2019 | 09:09 PM
Dusty Dc's Avatar
Hi guys. I just finished building g my engine bay. Been working on the plugs and wiring of the car. For some reason I keep blowing the fuse beside the battery. I've traced everything and find no exposed wires. Any ideas?
Old Apr 2, 2019 | 09:15 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuse beside battery.
Does it blow with the ecm disconnected ?
Old Apr 2, 2019 | 09:16 PM
Dusty Dc's Avatar
I hadnt tried that. I will check on that tomorrow. What's it mean if so or if not.
Old Apr 2, 2019 | 09:33 PM
Engine: Lb9
Transmission: M20
The fuse powers the ecm and the fuel pump.
if either is shorted the fuse would blow. If the fuse pops while both are unplugged than the orange wire is shorted to ground.
Is this speed density ? I don’t see a maf ?
Old Apr 2, 2019 | 09:35 PM
Dusty Dc's Avatar
Not SD. Emission removal chip.
Old Apr 2, 2019 | 09:37 PM
Engine: Lb9
Transmission: M20
here is a schematic of the pump/ecm wiring. The ecm cavity’s are specific to 90-92.
Old Apr 2, 2019 | 09:40 PM
Dusty Dc's Avatar
Mines an 87. First gen gta. Does that make a difference? And if you could clarify. If I unplug the ECU it means the fuel pump. If I unplug the fuel pump it's the ECU and if I unplug both it's the (now inline fuse)? It started doing it when I plugged Into the fuel pump relay. Does that help?
Old Apr 2, 2019 | 09:42 PM
Engine: Lb9
Transmission: M20
you still need a maf
Old Apr 2, 2019 | 09:43 PM
Dusty Dc's Avatar
Its run without maf for years no issue until I took it apart for the cleaning and powdercoat
Old Apr 2, 2019 | 09:44 PM
Dusty Dc's Avatar
The chip also deletes the maf and burn off from the ecm.
Old Apr 2, 2019 | 09:47 PM
Engine: Lb9
Transmission: M20
As you can see the wire powers the maf power, ops, ecm and fuel pump relay.
It could be a pinched wire grounding . If it started when you plugged in the pump relay check the wiring at the relay and try it with the pump disconnected at the rear body connector by the tank to see if it’s the pump itself.
Old Apr 2, 2019 | 09:50 PM
Dusty Dc's Avatar
The pump is newer but I will check that tomorrow. I believe it has to do with the wiring to the relay I just have to figure out how. I will do as you suggest and reply back here tomorrow with my findings. I appreciate the immediate response.
Old Apr 2, 2019 | 09:58 PM
Engine: Lb9
Transmission: M20
look by the relays for a grounded orange wire.
Old Apr 3, 2019 | 07:43 AM
Dusty Dc's Avatar
Mines black but its grounded.
Old Apr 3, 2019 | 09:05 AM
GeneralDisorder's Avatar
Who made this chip? As far as I know that's not possible and have it run any kind of decent. They may have deleted the codes but it should still have the MAF sensor.. I would bet my lunch that it's running like crap in limp mode for all these years. You can't delete the MAF from a 7165 ECM with a "chip"
GD
Old Apr 3, 2019 | 09:12 AM
Dusty Dc's Avatar
Its run fantastically for years with no issue. No limp mode. No issues. This is the same setup my father ran in his down the track for years.
Old Apr 3, 2019 | 11:07 AM
Drew's Avatar
This thread makes my head hurt.
That ground a few replies back has nothing to do with the engine. That there is the ground for cruise control and/or the fog lights.
You can unplug a MAF and the ECM will default to a set of values to allow the engine to sorta run, but it's certainly not optimal or desirable. Just as a general blanket statement, EFI either has to measure the air flowing into the engine so it can meter the proper amount of fuel, or it uses a MAP sensor to calculate air flow based on engine vacuum. But all that is beside the point. A fuse blowing indicates there's an electrical problem, not a fuel management issue.
The greater issue is that without a fundamental understanding of how a system is designed and intended to work, you can't very well go about trying to improve on that design by modifying it yourself. You go changing things and hacking away, then when you've thoroughly screwed things up, you can't go back to the well of knowledge seeking advice. The system is no longer how it's supposed to be. The only person knows what you've done, what you've changed, is you, and you clearly have no idea what you're doing.
I'd tell you to put down the Sawzall and step away, but it's too late now. I wish I could have been there for you brother.
Old Apr 3, 2019 | 11:09 AM
Engine: Lb9
Transmission: M20
Old Oscar
https://www.thirdgen.org/forums/afte...nc-review.html
Old Apr 3, 2019 | 11:12 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
What does your engine now use to measure the flow of air it intakes?
ETA:
NVM, opie; post #18 explains everything.
Good luck with your performance goals for 2019.
Old Apr 3, 2019 | 11:16 AM
Drew's Avatar
Nothing.
Didn't you read the thread, he cleaned up the engine bay and beautified it by throwing away all that ugly stuff that made it actually start and run. Now it's a bonfire looking for a place to combust. It's no longer transportation, or an automobile, it's yard art with a sole redeeming quality of being a 3000lb tool to test the failure point of fuses.
Old Apr 3, 2019 | 11:22 AM
Nothing.
Drew isn't wrong. You ABSOLUTELY CANNOT delete the MAF (without going to speed density with EBL, or rewire to a 7730, etc) on a 7165 ECM and it still be "right".
It may run, but you are leaving a lot of performance and driveability on the table.
Regardless of what you *think* is happening, without the MAF, the 7165 IS IN LIMP MODE without it's MAF.
GD
Old Apr 3, 2019 | 11:36 AM
Engine: Lb9
Transmission: M20
might as well run a carb
Old Apr 3, 2019 | 11:37 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Nothing.
LULZ
Drew isn't wrong. You ABSOLUTELY CANNOT delete the MAF (without going to speed density) on a 7165 ECM and it still be "right".
GD
^^^^THIS.
It's "comforting" to realize that bodybuilding/fitness/nutrition forums aren't the only internet sites where confused posters ask oddball questions.
Old Apr 3, 2019 | 12:01 PM
Engine: Lb9
Transmission: M20
The wire isn’t going to be purposely grounded. A short to ground is caused by a hot wire connected directly to ground or a component shorted out. Sounds like with the wiring being tampered with there is a loose wire maybe at the maf power that’s shorted to ground.
Old Apr 3, 2019 | 01:44 PM
Drew's Avatar
I'm still trying to wrap my head around "I just finished building my engine bay" followed shortly by a picture of the genesis of a rust hole in the same engine bay that is theoretically "finished".
What do you mean "Ignition coil"? I got an emissions delete chip! Don't need that **** cluttering up the place. John Force doesn't need no ignition coil, and neither do I!
Old Apr 3, 2019 | 02:12 PM
Dusty Dc's Avatar
Where do you see a rust hole? Are you blind?
Old Apr 3, 2019 | 02:30 PM
That whole corner is looking fairly scabby. But perhaps it needs a good cleaning. I do see surface rust on more than one fastener for sure. That "chip" you bought is clearly a scam if you have no MAF connected and the SES light isn't on. That's basically criminal, or at least criminally stupid.
GD
Old Apr 3, 2019 | 02:48 PM
Dusty Dc's Avatar
No rust just leaves. Paints chipping a little from where the PO did a paint over and didnt prep proper but the rest of the car is immaculate. No rust. No dings or dents. Whole reason I bought the domestic.
Old Apr 4, 2019 | 08:07 AM
RJ IROC's Avatar
Car: 1985 Camaro IROC-Z
Engine: 383 HSR Comp XFI280HR Profiler 195s
Axle/Gears: 3.73 Posi
Oh man, you have one of those "John Wayne custom chips". At least, that's what his name was before he got removed from the most popular thirdgen facebook pages for scamming people.
Another note that everyone else has made plainly clear, you need a MAF (or MAP depending on year) to run the car properly.
To be honest, it grinds my gears when people remove things because "It'll look better" without those components. Save yourself the trouble and do the research before you start yanking out the most critical components of the engine bay.
SBCsonoma91
Oct 3, 2012 08:47 PM
techno101
Jul 22, 2006 02:02 PM
Steve89GTA
Mar 24, 2003 12:10 PM
Daz
Apr 8, 2002 10:15 AM
84,86,88Z28
Car Audio
Oct 16, 2001 12:58 AM
