Modification cooling system
Old Apr 16, 2019 | 06:41 PM
miche25's Avatar
Car: Camaro 1984
Is a radiator trans oil strong enough to be used in a car cooling circulation system (example: replacement Heater core)
Old Apr 16, 2019 | 09:11 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Modification cooling system
Yes,they can handle much higher pressure than coolant radiators or heater cores.
Old Apr 17, 2019 | 05:42 AM
miche25's Avatar
Car: Camaro 1984
o.k If I understand this principle correctly, otherwise (trans oil by heater cor) the system will be unfit and may break down.
Thank you very much for your good cooperation !!!
Old Apr 17, 2019 | 02:48 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Yes, but you may not have enough coolant flowrate through it to do any real heating. The inlet and outlet tubes are much smaller than a heater core.
Old Apr 17, 2019 | 08:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's what I was thinking also. Typical heater cores use 5/8" or 3/4" hoses to move a lot of coolant through the core. A transmission cooler might have as large as 3/8". Although it would probably be enough to keep frost off your windshield, I doubt it would be enough to heat the interior.
CatmanFS
Dec 22, 2014 08:45 AM
customblackbird
Jul 27, 2011 10:31 AM
Jza
Oct 27, 2001 03:30 AM
shotgun
Car Audio
Sep 29, 2001 12:48 AM
