Serpentine conversion
Old Apr 28, 2019 | 01:44 PM
Cadmaro's Avatar
Car: 85 Camaro
Engine: Cadillac 500
Transmission: TH400
Axle/Gears: 9 bolt
I'm sure this has been beat to death but I can't seem to get the search to cooperate with me in finding the right threads.
I want to know which vehicle(s) I can get the serpentine set up off of that with my 85 trans am. I have most of the accessory drive off an 90 suburban, but I don't want to track down the missing parts if it won't work. Thanks in advance for any insight!
Old Apr 28, 2019 | 01:53 PM
Drew's Avatar
Re: Serpentine conversion
The truck setups aren't the same. They sorta look the same, but they're not. You're pretty much stuck with GM RWD cars from the 88-96'ish era. That means Camaro, Firebird, Caprice, Oldsmobuick and Cadillac big body. You might want to look at some of the cars with the 4.3 V6 for something that might work, but I'm not sure if they're the same as the V8 car setup.
Old Apr 30, 2019 | 12:26 PM
Cadmaro's Avatar
Car: 85 Camaro
Transmission: TH400
Axle/Gears: 9 bolt
In that case, would I be better off to buy the setup from an fbody? There was one on eBay for around $300 the other day.
Old Apr 30, 2019 | 01:25 PM
Drew's Avatar
If you can't find a "good" deal on a used setup ($300 ain't bad if it's all there), you might consider the GM Performance Parts serpentine setup (GM #12497697). It's a bit expensive, but you're getting all new parts, all the nuts and bolts, everything you need to the smallest brace. Should be available from Jegs, Summit, any of the usual GM dealers, or your local GM dealer if you want to pay list price. Speaking from personal experience, some of the bolts are unique and hard to track down, and various braces, etc are typically missing from used sets. If you can, try to find a donor car so you can take EVERYTHING retaining and supporting the brackets to the engine. It'll save you a lot of time.
I'll try to attach a tutorial from my notes (not my work) and the GM instructions (also stolen) to this message...
File Type: pdf
Old Apr 30, 2019 | 01:26 PM
Drew's Avatar
One more try...
Just one more note... The 88 setup is a bit unique. 89-92 are all pretty much the same. 88 being the first year, used different nuts and bolts, different support braces, blah blah. The 89-92 set is a little less complicated and more common.
Old Apr 30, 2019 | 01:52 PM
Cadmaro's Avatar
Car: 85 Camaro
Transmission: TH400
Axle/Gears: 9 bolt
I'm really hoping to avoid the gmpp route as that really kills the budget nature that I'm trying to keep with this project! But thanks for the info! I will keep and eye out for a suitable car to hit the pull-a-part yard near me.
ANDYZ28
Jan 10, 2008 07:18 AM
Bazookajoe254
Feb 20, 2007 10:48 PM
john5.7 87Iroc
Oct 21, 2001 03:10 PM
MarkS
Sep 10, 2001 08:56 AM
