Engine dies after moderate to heavy braking.
Old May 6, 2019 | 02:55 PM
loki03xlh's Avatar
Car: 1990 Firebird Formula
Engine: 305 TBI
Axle/Gears: ???
1990 Formula 5.0 TBI. In general, it runs "ok" for a 29 year old car. Main issue is that the motor dies whenever I have to use moderate to heavy braking. i.e., someone pulls out in front of you, light changes to yellow on a street with a decent speed limit. After popping the shifter into neutral, the engine will fire right back up. Any ideas?
Old May 6, 2019 | 03:01 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Re: Engine dies after moderate to heavy braking.
Could the "moderate to heavy braking" be impacting Vacuum/MAP causing the stall? Like a vac leak in break booster or in the lines to the Vac ball or Intake? Just bouncing ideas until a Sr member chimes in.
Old May 6, 2019 | 11:57 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
So basically when the engine is dragged down to idle quickly then it undershoots and dies? Sounds like it could be starved of air.
Old May 7, 2019 | 10:18 AM
loki03xlh's Avatar
Engine: 305 TBI
Axle/Gears: ???
I will check all vacuum lines later this week when I get a chance. Thanks for the tip.
Old May 7, 2019 | 10:20 AM
loki03xlh's Avatar
Engine: 305 TBI
Axle/Gears: ???
The motor/intake is bone stock, air filter has less than 200 miles on it. I will be doing ultimate tbi upgrade later this spring. Hopefully that will increase airflow.
Old May 7, 2019 | 11:09 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I was talking about idle air flow with throttle blade closed. As in throttle blade position, failed IAC valve, vacuum leaks causing idle instability etc...
Old May 7, 2019 | 01:04 PM
loki03xlh's Avatar
Engine: 305 TBI
Axle/Gears: ???
I see what you are saying. I have an extra IAC valve in my spare TBI unit. I'll swap them out and see if it makes a difference.
Old May 7, 2019 | 02:17 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
you might try putting a t-fitting in line with the brake booster line, put a vac guage on it, and pump the brakes a bunch. see how vacuum reacts.
Old May 7, 2019 | 03:14 PM
Probably not anything to do with vacuum.
More likely, fuel starvation.
Fill the tank. NOT, put gas in it; FILL IT. If it clears up you just found your problem.
Old May 8, 2019 | 10:49 AM
loki03xlh's Avatar
Engine: 305 TBI
Axle/Gears: ???
It acts the same whether the tank is full to the filler neck or sitting at a quarter tank.
Old May 8, 2019 | 10:58 AM
LiquidBlue's Avatar
Transmission: MD8
Well that sucks, because the gas tank problem is certainly an easier fix! I thought Sofa was on to something. These cars are known to have fuel starvation problems when tank is low, but I think general consensus around here is that around 89ish all cars received baffles, which fix the issue. however, the baffles do get old and break from what i have heard. still lots of rumors on this issue
Old May 8, 2019 | 11:01 AM
LiquidBlue's Avatar
Transmission: MD8
BTW - you may be able to simulate this problem by just pumping the brakes a bunch while at idle. see if anything happens. easy test.
Old May 8, 2019 | 03:33 PM
loki03xlh's Avatar
Engine: 305 TBI
Axle/Gears: ???
The fuel tank was replaced about 5 years ago. The car sat for about 14 years with about half a tank of gas. It was cheaper to replace than clean.
Old May 8, 2019 | 03:44 PM
LiquidBlue's Avatar
Transmission: MD8
still got that gas tank? i'm looking for one.
Old May 8, 2019 | 06:58 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
What he said.... Had it happen, does your tank have the baffles in it?
Old May 9, 2019 | 12:52 PM
loki03xlh's Avatar
Engine: 305 TBI
Axle/Gears: ???
Sorry, it's long gone.
1986Z28OWNER
Nov 8, 2009 03:56 PM
zray
Carburetors
Aug 25, 2009 01:09 PM
92RS shearn
Apr 29, 2003 12:57 AM
maksik7
Jun 20, 2001 09:38 AM
JDMZ28
Carburetors
Jun 4, 2001 10:26 PM
