Valve Seals replacement California Emissions Test
Car: 1986 Chevy Camaro Berlinetta
Engine: 305 V8 5.0 carb.
Transmission: Automatic
Axle/Gears: the kind that came with the car...
Would having worn valve seals on a carbureted 305 v8 receive an automatic fail for california emissions test? I'm due for a test in July of this yr and just wanted to know.
Engine: LB9 305
Transmission: AT
Re: Valve Seals replacement California Emissions Test
iF THE SYMPTOMS OF THE WORN SEALS INCLUDE SMOKE AND higher emissions, yes.
Engine: LB9 305
Transmission: AT
I don't recall seeing worn valve seals damaging AIR tubing. Typical is oil fouled plug(s) and sometimes, blue smoke, on startup, after a brief warm shutdown.
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
You could try running a heavier oil for just the test. Might be enough to minimize the seal leakage for the test.
Also, throwing in a set of fresh plugs would help too.
FWIW, on my LB9 I have two oil rings that are less than 100% (one plug fouls in several months, the other very slightly, but does). My car passed with flying colors. I suppose it depends on how badly they are leaking. If you can drive the car without adding oil every week, it might pass. I would TOTALLY GUESS that if you aren't adding more than a quart every thousand miles or so, it might pass. Just a WILD guess.
Lastly, some shops offer a free, or $10 retest within a period of time after the fail.
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
If there is visible smoke at idle or when you gun the engine, you will fail.
If you have high hydrocarbons, NOX or CO you will fail.
If you don't have everything under the hood hooked up you will fail the visual exam. They will look underneath for a cat as well. If your cat is really old, you may fail.
You may want to try running 20W50 oil for the test. Make sure your air filter is clean. Dump a can of Seafoam and a jug of Gumout Regaine total fuel system cleaner (the stuff with PEA) in the tank and run that through before you test. Make sure the plugs, wires, cap and rotor are in good shape. Make sure your tires are nice and firm for the treadmill test. Get some spray carb/choke cleaner and spray that down its throat before the test.
Make sure the engine and cat are fully up to temperature when you take it in.
If your SES light does not work, you will fail. If the SES light is illuminated constantly, you will fail.
If you have a puff of smoke at startup that is OK. Just no visible smoke at idle or when you gun the engine. The smogger will sit in the car and look for smoke through the rearview mirror or turn his head. He will gun the engine 2 or 3 times. There should be no smoke when he does that.
The smogger will check to see if the SES light works. It will light up when the key is on but the engine is not running. he will look for that. When he starts the engine the SES light has to go off and stay off.
Here in Cali we have alcohol gas year round now. Alky burns real clean. You can cheat a bit by buying a can of denatured alcohol at Lowes and dumping that in the tank to increase the alcohol percentage in the gas. That will make the engine burn a little cleaner. Might make a difference.
Good luck.
Good luck.
Engine: LB9 305
Transmission: AT
I................................................................. You can cheat a bit by buying a can of denatured alcohol at Lowes and dumping that in the tank to increase the alcohol percentage in the gas. That will make the engine burn a little cleaner. Might make a difference.
Good luck.
Good luck.
Engine: LB9 305
Transmission: AT
I know a guy, who runs his fuel tank to about 1/4 full, or less, then adds approx. 4 bottles of HEET brand moisture remover/fuel line deicer. It contains Isapropol or methyl Alcohol. (Red or yellow bottle, I forget which is which). The alcohol helps it burn cleaner, add gasoline right after testing.
Engine: LB9 305
Transmission: AT
IMO, it comes down to what's readily available.
Last time I tried to buy Denatured Alcohol, it got flagged at the Walmart register as "Do not sell, remove all like items from display". Maybe a F-ING Cali thing. I haven't tried Lowes or HD.
Mike that is bullshit. I also live in NorCal and see that stuff on the shelf all the time in Lowes and Home Depot. I've bought cans of the stuff several times with never an issue. If anything it is a Wally's World thing. There are no laws on the books preventing people from buying solvents. If you live anywhere other than the extreme boondocks, you should have a Lowes or HD within a few miles.
86FyrBrd
Jan 17, 2013 07:34 PM
