Shimming starter with T5
Old Jun 11, 2019 | 06:02 PM
ndndndnd's Avatar
Car: '85 IROC-Z
Engine: 305cid
Transmission: 5-speed
Hello, I'm sure this question's been asked before but I can't find it anywhere.
I'm about to purchase a mini starter to deal with my heat soak issues, but I'm wondering quite what I do about shimming the starter and checking the engagement is correct. I believe with the Auto trans you can simply see, but my car is a T5 and I can't see how you can check the engagement without removing the gearbox!
Is removing the gearbox the only way to be sure, or will I be ok going by trial-and-error? Is there a good trial-and-error method or shall I stick it on with no shims and see if it works?
Many thanks for any advice/admonishments!
ND
Old Jun 11, 2019 | 09:32 PM
Re: Shimming starter with T5
Put it on and try it. It's usually really obvious if it needs shims. If it sounds quiet and spins fast, and disengages properly when you let go of the key, it's fine. If you then think you want to try shimming it just to see what happens, put in a good bit, like 1/8", and go from there.
Old Jun 12, 2019 | 01:01 AM
ndndndnd's Avatar
Car: '85 IROC-Z
Engine: 305cid
Thanks sofa - maybe I'm over-thinking this. I'll get it bought, and then maybe I can stop crossing my fingers before trying to restart at petrol stations!
Cheers,
ND
Old Jun 12, 2019 | 12:56 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
An LT1 starter is better than a mini starter and cheaper.
Old Jun 12, 2019 | 01:36 PM
RJ IROC's Avatar
Car: 1985 Camaro IROC-Z
Engine: 383 HSR Comp XFI280HR Profiler 195s
Axle/Gears: 3.73 Posi
It IS possible to check it, even with the T5... A real PITA though. One way to check the engagement would be to paint the teeth on the flywheel, crank it over a few times, and see what rubbed off. A more reliable method is to use a paperclip. It should fit between the tip of the teeth of the starter gear and the flywheel with the starter gear engaged. I used a small wedge-shaped piece of metal to hold the starter gear out. I had to bump the solenoid a couple of times (MAKE SURE THE CAR IS IN NEUTRAL) to get the gear to come out. Once the gear was engaged, I bent a hard 90 onto the end of a paperclip with probably a 1/4" or so sticking out. I straightened out the rest of it, and was able to snake it in between the gears.
I completely agree with Vincent; The LT1 starter is the way to go.
If it engages without pegging the flywheel, and completely disengages, you're probably pretty close. Be sure to clean the starter pad to ensure adequate grounding to the starter. I'd also recommend new starter bolts if the knurls on your old ones are even slightly worn. ARP makes a great stainless bolt kit for this.
evilstuie
May 18, 2016 08:07 AM
adamwbennett
Apr 17, 2010 09:46 PM
91greenbird
Oct 14, 2007 07:15 PM
BanditMan
May 28, 2006 10:43 PM
D_Amlee
Sep 23, 2001 02:34 PM
