Fuel Pump
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Fuel Pump
How do you test power going back to the fuel pump in the tank? I replaced my fuel pump because it was not priming when I started the car. Now it still will not prime to start my engine. I need help to determine where the problem is. Thank for any help I receive.
Re: Fuel Pump
That should give you someplace to start , and here is a diagram for your fuel pump wiring showing the wires I mentioned .
Car: 1987 IROC-Z
Engine: 5.7 TPI
Re: Fuel Pump
I did the test with both wires to ground and neither one of them lit up when turning the key to the on position. I guess that means I have a bad ECM. The light does light up when you go from ground to the orange wire. So I know I have power coming in on that wire. If anybody can help me with this please let me know what I need to do to get this car going again. Thank in advance for the help.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Fuel Pump
Not positive but could this be vats related as well, as i think its suppose to cut fueling. Not sure if pump prime tho or if injectors
Has engine wiring been modded at all? or ecm been handled in anyway that would damage any wiring coming out? I guess ecms can go bad but i cant say i have seen that happen.
Car: 1987 IROC-Z
Engine: 5.7 TPI
Re: Fuel Pump
The wiring has not been changed at all. That's why I thougth that it was the ECM that was the problem. Thanks for the help. I will keep testing until I find the answer.
Re: Fuel Pump
You can't be sure the ECM is bad till you test powers and grounds to the ECM, and Ohm the wiring from the ECM to the fuel pump relay. It would also be wise to initiate communications with the ECM to see if it will talk to you.
Also as mentioned it might be a VATS issue - I am not sure if the ECM will perform the prime without the VATS module signal. Is the security light on when you are trying to crank? VATS should also disable cranking but someone may have bypassed the relay in the kick panel. That's very easy to do.
In the VAST majority of cases, the "damn computer!" is not the problem. Not that it's impossible, but people always try to blame the thing they don't understand and it's usually not the problem.
GD
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Pump
87 f body doesn’t have vats. The 2 second prime still happens even if a vats system isn’t working on vats equipped cars.
kowboy59
Nov 7, 2011 09:36 PM
BuckeyeROC
Apr 29, 2002 07:18 PM
