What's this clicking sound?
Old Jan 10, 2002 | 02:24 PM
lavamadness's Avatar
Car: 1989 Formula 350
Engine: 5.7L (L98)
When my car is idling, either in Park or in Drive at a stop, I can here a clicking sound like something switching, and my RPMs will go up by 50 or so.. then after a few seconds it'll click again and it'll drop by 50 or so. It'll do this repeatedly... The RPMs stay at around 600-700 for all of this.
Old Jan 10, 2002 | 03:07 PM
Engine: 5.7L (L98)
Oh, and it's a stock L98.
Old Jan 10, 2002 | 04:58 PM
89bonestockiroc's Avatar
What your describing sounds like what mine used to do. I think it may be your cooling fans. Are they electric? Before my engine swap, my car did exactly the same thing. It doesnt do it anymore, but I have a new battery, new alternator, and new engine.
Old Jan 10, 2002 | 05:25 PM
Engine: 5.7L (L98)
If it's the cooling fans, is there some way to fix it. It's getting annoying when I'm waiting in the line at a drive thru. The click occurs every 5 seconds or so.
Old Jan 10, 2002 | 05:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A/C compressor?
Old Jan 10, 2002 | 05:55 PM
Engine: 5.7L (L98)
AC is rarely on.
Old Jan 10, 2002 | 06:43 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Maybe the A/C compressor is cycling on and off when it shouldn't be. Watch the compressor while you're idling in park and see if it it turning on and off.
Old Jan 10, 2002 | 07:20 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I hardly know TPI, but I thought someone once said something about the fuel injectors.
Old Jan 11, 2002 | 02:38 AM
Engine: 5.7L (L98)
Yup, it's the AC compressor. Thanks for the help!
Just a couple of quick questions...
Should the compressor be cycling when the AC isn't on?
Should it click on and off that often? I had to drive around for about 15 minutes to get it happening. It would turn on for 4 seconds, then shut off for 8-10 seconds.
Old Jan 11, 2002 | 08:00 AM
Damon's Avatar
The compressor should not be cycling unless the A/C is turned on (or the Defrost setting).
Anyways, it should never cycle every 5 seconds even if it is selected. That's way too quick.
First thing I'd do is borrow a scan tool and see if the ECM is requesting the A/C clutch to be turned on and off or if it is doing it on it's own. The ECM is the only thing that should be able to turn the A/C compressor on and off. So if it's doing it on it's own you have electrical problems.
I suspect that the HVAC controls in the dash have gone screwy on you, however, if I had to make an educated guess.
Old Jan 11, 2002 | 08:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right... A/C is supposed to run when the control is in defrost.
It shouldn't cycle like that. If it does, it's because it's very low on Freon. It has a low pressure switch in the low side of the system that cuts the compressor off when the pressure falls below about 25 psi, which basically will never happen when the system is full.
Old Jan 11, 2002 | 11:50 AM
Engine: 5.7L (L98)
Old Jan 11, 2002 | 02:26 PM
Engine: 5.7L (L98)
Would there be any problem with disconnecting the wiring harness to the AC compressor so it doesn't come on? I would think the constant cycling isn't helping the clutch in it, and it does get annoying. It would be nice if I could disconnect it until I had the time and money to try and find the problem (got other problems with the car at the moment...).
Old Jan 11, 2002 | 02:40 PM
Engine: 5.7L (L98)
Oops... sorry for the double post... hit refresh on my browser..
Old Jan 11, 2002 | 11:24 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
No, you will not hurt anything if you unplug the compressor. When I used to live in NY I would unplug it during the winter cause I did not want the compressor comming on every time I used the defroster. Also is sounds like your AC is getting low on freon and soon you compressor will not engage because of low pressure in the system.
Old Jan 11, 2002 | 11:29 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Which is what RB83L69 just posted. Did not mean to be repetitive.
Old Jan 13, 2002 | 02:14 PM
Engine: 5.7L (L98)
Went to unhook the wiring harness from the AC compressor but found two harnesses going to it. One at the back of the compressor, and a smaller on up towards the front where the pulley. What is each one for? And what should I unhook? (I suppose I could have just unhooked them both, but I don't like guessing.)
Old Jan 13, 2002 | 09:49 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I would unplug the one that is just behind the pulley, that is the one that engages the clutch on the compressor. The other one is a high pressure cut-off switch. (I think)
Lbibb
May 5, 2016 12:00 AM
wanext
Oct 6, 2015 12:18 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
