Modifying vortec heads
Old Jul 27, 2019 | 02:15 PM
Logan Bryant's Avatar
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I just picked up a set of vortec heads and they just so happened to not be cracked! So now I'm looking to swap them onto my sbc. But my cam had to much lift for the heads. For everyone that has used the comp tool, what all do I need to make this possible to have more lift?
Old Jul 27, 2019 | 02:43 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Modifying vortec heads
Comp 787 retainers
0.050" offset locks
Behive springs.
Be sure to measure but if you have the valve seals fully seated this should give you just under 0.600" retainer to seal clearance and allow you to run a 0.550" lift cam.
Old Jul 27, 2019 | 06:40 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Would these be the same, but all in one package?
Old Jul 27, 2019 | 07:51 PM
Won't fit your heads.
The retainers, keepers, seal, and guides are for LS valves, which are different from SBC ones..
Old Jul 28, 2019 | 05:19 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Had anybody used the comp tool 4726?
Old Jul 28, 2019 | 05:26 PM
I've used a couple of those. Worked fine for me.
Old Jul 28, 2019 | 07:15 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Mostly because it would be almost $300 just for springs, retainers, and deals if I went the beehive route. I would rather spend less than that and be able to use cheap springs
Old Jul 28, 2019 | 08:09 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You can get 787 retainers and GM beehives for $200 or less and 0.050 offset valve lock keepers are cheap.
ChevyRacer
Jun 8, 2005 10:22 PM
Ukraine Train
Feb 5, 2002 09:05 PM
mcconahay37
Aug 1, 2001 05:33 PM
