Car Won't Idle
Old Jan 10, 2002 | 08:26 PM
Camaro1984's Avatar
Car Won't Idle
Before i garaged my car... it would never idle unless i got it warmed up. The other day i went to start my car to warm it up. I start it and tried warming it up and then tried to see if it would idle... It wouldnt. So i tried again. It wouldnt start back up. It sounded like it wanted to but it wouldnt. While trying to start it again it kinda sounded like a backfire... I heard something pop out of my exhaust pipes and it was a peice of the inside of my CAT. I looked under my car and my CAT is red hot... Over the last summer the car just recently had a new CAT put in.. It also puffs out black smoke and it ust recently started when it got cold. Not sure if its a coincedence or the cold is causing it.
Old Jan 10, 2002 | 08:43 PM
SgtSkip's Avatar
Carb maybe??
Old Jan 10, 2002 | 09:14 PM
Camaro1984's Avatar
I dont think it is the carb. Cause the cat turned red from the heat.... Like its backed up or something.. I dont think the carb would cause the CAT to turn red... At first i thought it was the carb making it not idle so i bought a new carb just didnt put it in yet.
Old Jan 10, 2002 | 09:29 PM
DiecastZ28's Avatar
Could the CAT be clogged from the car running to rich. Doesnt that what black smoke means?
Old Jan 11, 2002 | 06:33 AM
SgtSkip's Avatar
That's kinda what I was thinking.
Old Jan 11, 2002 | 01:19 PM
Camaro1984's Avatar
So do you think I should Cut off my cat and see if it runs fine... And im going to be throwing on that Holley 4 barrel. I still have the stock carb on.. Just waiting to put new one on.. Not sure what to do. But thanks for the help
Old Jan 11, 2002 | 02:42 PM
89Irocz23's Avatar
if I was you I would cut the cat off, bolt the new carb on, also buy a higher flowing intake manifold. With doing all that you get more horse out of it.
Old Jan 11, 2002 | 09:05 PM
DiecastZ28's Avatar
TTT
Old Jan 13, 2002 | 09:57 AM
DiecastZ28's Avatar
TTT
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
zeitghaist
Aug 18, 2015 07:33 AM
ZsTransAm
Aug 11, 2015 07:30 PM
