need advice on high idle-SOLVED
Old Nov 7, 2019 | 09:34 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
this morning when I started my car the idle seemed high. I wrote it off to the cold weather. however when I drove to work I noticed the idle was much higher than usual. with my foot off the throttle the idle was high enough to keep me going about 40mph at 1100rpm. when I put it in park the rpms shot up to 2,000rpm. car drove fine. at first I thought it was probably the tps but now im thinking maybe a vacuum leak. what say you? if its a vacuum leak where are the most common areas to check? just around the throttle body?
Old Nov 10, 2019 | 06:44 PM
Evilokc's Avatar
Engine: tbi 305
Re: need advice on high idle
spent about an hour on this last night. I read a few threads about it and followed their trouble shooting. I tested the tps by unplugging it while the car was idling to see if the idle changed. it didn't. I unplugged the air intake charge sensor while the car was at idle to see if that changed the idle speed. it didn't. I sprayed around the throttle body looking for vacuum leaks and didn't fins any. I gave up and put the car back together and it worked. the idle had returned to normal. nothing was weird. the check engine light was off. I was happy it was fixed but I really wanted to know what it was. today I started the car to pull it out of the garage and the idle shot back up immediately and wouldn't come down. the check engine light was flashing again. that in itself is odd that it flashed with the rpm instead of just staying on. so back to the drawing board on this.
Old Nov 10, 2019 | 07:16 PM
NoEmissions84TA's Avatar
Step 1 - what code are you getting?
Old Nov 10, 2019 | 07:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Check engine light was flashing or on solid ?
Old Nov 10, 2019 | 07:51 PM
Evilokc's Avatar
Engine: tbi 305
check engine light was flashing. I just used a jumper to read the codes. I got a 22- tps reading low, 23- manifold temp sensor reading low, and 51 prom fault. is all of this from a prom fault? I put in an aftermarket chip about 3 months ago. its been running much better than on the stock chip until now.
Old Nov 10, 2019 | 07:59 PM
Engine: Lb9
Transmission: M20
It sounds like a bad ecm or it could be a bad prom. I would try to install your old prom and see how it runs.
erase your error codes by disconnecting the battery for 10 min or so.
the flashing engine light indicates the engine is running in limp home mode not off the prom.
you might be able to source a used ecm in the classifieds you need a service number 1228746 used in
89-92 tbi
Old Nov 10, 2019 | 08:17 PM
Evilokc's Avatar
Engine: tbi 305
I have the old prom. will put it back in tomorrow and see what what. appreciate the help guys.
Old Nov 10, 2019 | 08:20 PM
Engine: Lb9
Transmission: M20
It’s odd that the new prom would be the problem. It could be a bad connection where the prom seats in the socket.
Old Nov 10, 2019 | 09:22 PM
Evilokc's Avatar
Engine: tbi 305
I thought about it being a bad connection as well. I will verify that the chip is seated well and try again with it. besides switching the proms is there a way to verify the ecm is good?
Old Nov 10, 2019 | 09:59 PM
Engine: Lb9
Transmission: M20
You can wrap on the ecms case with a screw driver handle while the engine is running to see if it acts up.
no other test I know of to help you verify if the ecm is bad .
Old Nov 16, 2019 | 02:59 PM
Evilokc's Avatar
Engine: tbi 305
I have the computer pulled down and im ready to pull the aftermarket chip and reinstall the factory chip. will the factory chip install in the same direction as the aftermarket? both have a notch one end. I know it will install in both directions but the wrong way will fry my ecm. so which direction does the notch face? im going to pull my manual but I like checking in with you guys as well.
Old Nov 16, 2019 | 03:29 PM
Engine: Lb9
Transmission: M20
http://westersgarage.eidnet.ca/EPROM%20Procedure.pdf
this shows the direction the prom holder is inserted into the ecm. Look at the notch in the holder.
Old Nov 16, 2019 | 03:46 PM
Evilokc's Avatar
Engine: tbi 305
okay read the manual and went to install the chip. when I was removing the aftermarket chip I noticed one enc was very loose. im thinking maybe it wasn't seated. I guess its possible it vibrated out. the factory chip was in a plastic holder. the aftermarket chip didn't come in a holder nor did the instructions say to put it in one. so maybe the lack of the chip being in a holder is the culprit? I pushed the aftermarket chip back in and everything is working fine. im going to give it an hour then try again to see if its working. would be nice if this is just a case of a loose prom.
Old Nov 16, 2019 | 05:04 PM
Pin #1 is identified by a dot, or to the left of the notch, for those that don't know.
Old Nov 16, 2019 | 05:54 PM
Evilokc's Avatar
Engine: tbi 305
took the car out for about 15 miles. it ran great with none of the issues. im hoping that the loose chip was the issue and this will stay running right. last time I unhooked the battery the computer reset and it ran correctly for about 5 miles. I feel like ive driven far enough that I would know if it was going to fail again. will find out for sure tomorrow.
Old Nov 16, 2019 | 06:02 PM
I'm pretty confident you've found the problem.
Old Nov 16, 2019 | 07:03 PM
Engine: Lb9
Transmission: M20
Can’t believe someone sold you a prom without the holder. It really helps secure The connection.
Old Nov 16, 2019 | 08:53 PM
Evilokc's Avatar
Engine: tbi 305
I have some errands to run tomorrow. it will be plenty of miles to know for sure if ive got this thing beat. need to buy a holder for this chip.
Old Nov 17, 2019 | 11:35 AM
Engine: Lb9
Transmission: M20
Look at the junkyard for a holder 87-92 tbi trucks they are behind the glove box insert.
i have some but only have flat rate small shipping boxes so shipping would be a killer for such a small part.
Old Nov 18, 2019 | 08:56 AM
Evilokc's Avatar
Engine: tbi 305
Im far enough into driving miles now to say this has been corrected. The prom had vibrated loose on one end. I guess this is a best case. For now im going to tuck everything back under the dash. If this happens again i will need to locate a holder. Thanks to everyone who jumped in with advice to help me keep my bird flying.
ResonateEcho
Oct 4, 2024 06:01 AM
85Iroc-Z
Oct 28, 2009 12:28 AM
Timmie
Jul 17, 2008 08:54 AM
lesser85
Jun 16, 2005 01:36 PM
redline724
Mar 21, 2005 04:47 PM
