I have a crank no start on my 88 gta
Old Mar 5, 2020 | 12:57 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
Hi
today I got a new ecu still not starting
I have spark just now I sprayed half can of starting fluid in it and still not even a half start nothing
I have fuel pressure it's 50 psi ish
and I hear the pump run
I also changed the icm 2 days ago did nothing
I'm lost and I need help
I don't have a scanner
I'm gonna take 2 plugs out and see if it's fluded
pls help me
Old Mar 5, 2020 | 12:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: I have a crank no start on my 88 gta
Did you swap over the memcal ?
Old Mar 5, 2020 | 05:15 PM
bensbaby's Avatar
Engine: 383 built
I did swap it out of course
but now I get the gas smell from cranking it
and I took out 2 plug wires on diff banks and they both had spark with a screwdriver method
then for ***** I put my old plug in it and grounded it and zero spark on my plugs they are 2 years old and 2000kms
I used a old head spark plug grounded it on the same spot and it worked perfty
so I ordered some new plug here tomm and try them first
and I think my accel tpi coil that I bought years ago may be weak
I ordered a brand new one on eBay
today
I'm gonna change the plugs tomm and see after that
I'll let you know
it's crazy
Old Mar 7, 2020 | 02:55 PM
bensbaby's Avatar
Engine: 383 built
It was the spark plugs all along 2 years old
new a.c. delco plugs and it's runing like new again
it was 2 things
bad computer making the fuel inj not pulse and my stupid spark plugs
hopefully this helps someone
my1988gta
Apr 14, 2017 06:27 PM
jmopar
Apr 2, 2017 07:50 PM
TimMcLeod
Mar 19, 2014 04:49 PM
camaroman9191
May 11, 2012 01:48 PM
MMC
Jan 2, 2012 07:46 AM
