GTA cluster swap
Old Apr 19, 2020 | 04:11 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
GTA cluster swap
Hi all. Just a quick question. I have a 1987 trans am, came across what was described as a GTA 140 mph cluster. (almost free) the plastic housing on mine is white on the new one, its black. i put new cluster in, everything seems to work except the trip and odometer. mph works fine. could be from a diff year and wont work or can i just swap old mph gauge out. thanks in advance
Old Apr 19, 2020 | 06:36 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Re: GTA cluster swap
Heres what you need to fix your problem. Almost everyone of these have the same issue. Its just one gear and fairly easy to change just take your time and be gentle. I just did mine and works like it should.
Old Apr 19, 2020 | 08:34 PM
TOM305T/A's Avatar
thanks for the info. that gear cost more than the cluster. my original one works, it may be easier to just swap them
Old Apr 19, 2020 | 09:56 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Great Post; Thanx for sharing that info !!
Old Apr 20, 2020 | 08:38 AM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Trust me you will need to order the gear, my gear was fine too (just was locked up on the shaft), it was from a 50k car and the gear just crumbled to pieces when I tried to remove it. The gear that needs to be replaced is made from a different plastic than all the other gears, apparently the factory didn't want people tampering with the odometer so they put some kind of cheap gear that will break if someone tries to remove/tamper with odometer. Its well worth the money and a nice well put together kit.
Old Apr 20, 2020 | 07:53 PM
TOM305T/A's Avatar
thanks 2knight. im gonna order the gear
Old Apr 23, 2020 | 06:27 PM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Coincidentally, the odometer / trip odometer in my '91 GTA quit working this past weekend.
LS2Swapped92
Apr 24, 2017 08:42 PM
brdofpry85ta
Jan 23, 2013 08:24 AM
Mailbox Hunter
Aug 26, 2011 04:41 PM
Reddeath210
Jun 28, 2011 04:25 AM
Camaroz29
Sep 26, 2005 08:46 AM
