Need Help!, I'm lost.. I have a Power Loss Issue
Old May 3, 2020 | 06:27 PM
bigbluefan3's Avatar
Car: 1987 GTA
Hi, I am in dire need of some help as I am baffled and lost. I have a 1987 GTA I am the original owner car has only 11,000 original miles. Car has been my baby for 33 years. The issue I am having has been going on for a few years. Car runs great, starts right up drives like new, but after bringing the car up to temp driving it around then turning it off and letting it sit a bit is where things go bad. The car restarts perfect and drives then 5-15 min into driving the car it looses all power and you have to pull over or it will just stall out. I let the car sit only 2-5 minutes car starts right up and runs fine again Car is 100% stock 100% original no mods, never raced, here is what I have done to the car so far.
Dropped and flushed gas tank and replaced electric fuel pump that went bad (unrelated issue) I was having the power issue before and after fuel pump replacement.
New spark plugs, new cap and rotor
New gas filter and air filter
New OEM Bosch MAF sensor as I had one.
New engine Temperature sensor (upper front of engine)
I really thought it was my catalytic converter that might have been clogged so I replaced that with a Magnaflow cat.
But nothing worked, like I said car looks and drives like it did in 1987 but if I go to a car show I will no doubt break down on the way home.
Everything else is original other than fluids, I really need some help here as you can see car still has the dealer inspection sticker from 1987 in the front window. Thanks in advance!
Guy
Old May 3, 2020 | 11:27 PM
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
Re: Need Help!, I'm lost.. I have a Power Loss Issue
Have you checked any codes? Just a suggestion, but try a noid light and see if your injectors are dropping off when this happens. Your driver for them may be going bad, or the ECU itself may be going out.
Old May 4, 2020 | 05:10 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Two things come to mind, ignition coil or the map sensor.
Old May 4, 2020 | 06:33 AM
Car: 1987 GTA
Those came to mind,
Old May 4, 2020 | 06:35 AM
Car: 1987 GTA
not real familiar with a noid light, as for a code reader not real sure what would be the best reader
Old May 4, 2020 | 06:49 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I'd be looking at the ign coil, ign module and the pickup coil..
Old May 4, 2020 | 07:05 AM
Car: 1987 GTA
Thanks!
Old May 4, 2020 | 07:52 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Sounds like the ICM is on it's way out. Here's the steps to troubleshoot it: https://easyautodiagnostics.com/gm/4...ed-icm-tests-1
I'd suggest you start looking for a Helms (factory) shop manual for your car; they're invaluable when doing any type of repair/maintenance, and they're becoming more rare every day.
Old May 4, 2020 | 09:05 AM
Car: 1987 GTA
ICM, thanks for your input I am looking at the comments and I see a few different thoughts good info tho!
bigbluefan3
Sep 9, 2019 02:36 PM
xxpotandaxx
Mar 17, 2014 07:15 AM
erik69&85
Oct 14, 2011 10:48 AM
firebd89
Oct 27, 2007 10:56 AM
Motopsyco
Nov 9, 2003 09:46 PM
