Cross threaded crank
Old May 11, 2020 | 08:28 PM
Sling Meister's Avatar
Went to pull my lower timing gear off with a puller. Wasn’t paying atttention and ended up cross threading like the first 6 or so threads. How should I go about tapping it or should I just get a new crank. It’s from a 350
the gear puller was a different thread
Old May 11, 2020 | 09:02 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Cross threaded crank
Seems like you don't have much to lose by retapping it. I would also measure how deep the bolt reaches afterward and maybe buy the longest bolt you can fit before it bottoms out in the crank. A tap will reshape those buggered up threads, but there will be metal missing and you want max thread available for the bolt now.
Old May 11, 2020 | 09:26 PM
You can try tapping it, sometimes that works. Especially if you can get the tap to follow the original threads.
If not, just Heli-Coil it.
Old May 11, 2020 | 09:29 PM
If I tap it do I go by the original bolt size or do I go a size over
Old May 11, 2020 | 09:31 PM
Original
7/16"-14 (std thread) if memory serves.
DO NOT UNDER ANY CIRCUMSTANCES sodomize your crank by forcing some other thread in there.
Old May 11, 2020 | 09:33 PM
What does std thread mean
Old May 11, 2020 | 09:36 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
standard thread
Make sure you use a specific tapping oil or wd40 on the tap too
Old May 11, 2020 | 09:42 PM
I bought a new Timing set do I honestly need to put the new lower gear on or can I just use the old one and just skip having to take it off
Old May 11, 2020 | 10:51 PM
GeneralDisorder's Avatar
You should definitely replace that gear.
You can drill and tap the crank to the Chevy BB size. I have a '70 block in my Jimmy that this was apparently already done to when I got it (no clue why but seems likely that there was some kind of thread malfunctory). Found this out when I swapped balancers, etc. That engine makes about 350 HP with a cam and vortec heads so it doesn't seem to be any issue with upping the bolt size.
GD
Old May 12, 2020 | 06:33 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Well... You should DEFINITELY replace it.. Just sayin'...
slowfast
Aug 22, 2007 10:00 PM
graphicideas1
Aug 30, 2006 09:32 AM
ck76239
Jun 10, 2005 04:00 PM
CamarosRUS
Aug 23, 2004 01:55 PM
holmes677
Sep 4, 2002 05:06 PM
