Question about Edelbrock Valve Covers
Old May 19, 2020 | 08:35 PM
magicdave2's Avatar
Car: 1983 Pontiac Trans Am Recaro
Engine: CFI 305
I've got a quick question about my 1990 Firebird Formula with the TBI 305 engine. I recently acquired this car. As you can see in the photo, the PO added an Edelbrock open air intake and valve covers. These are the valve covers with only two holes. One for the PCV valve and the second for the breather/oil fill cap. For some reason, they put the oil fill under all the hoses on the passenger side and kept the PCV valve in it's typical place.
My question is, after having to remove hoses just to do an oil change, is there any reason I can't swap those two parts? Put the oil fill tube/breather on the driver side and move the PCV valve and hose to the passenger side?
Thanks!
David
Old May 19, 2020 | 09:35 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
Re: Question about Edelbrock Valve Covers
you should be able to swap sides just fine.
your valve covers are probably exactly the same, it probably just has a rubber filler cap. you can probably just swap the grommet and filler cap and run a new vacuum line.
Later,
Chris
Old May 19, 2020 | 10:08 PM
magicdave2's Avatar
Engine: CFI 305
Hi Chris, thank you for your reply. Sorry if I wasn't clear, my question was can I just switch the pcv valve and the breather/oil fill tube (not the covers themselves)?
According to the part numbers both the breather and the pcv valve use the same grommet. So, the only issue might be slightly lengthening the pcv valve hose.
But I wanted to make sure there wasn't a reason it was set up this way to start with.
Thanks!
David
Old May 19, 2020 | 10:37 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
If there is a difference in your engine vacuum between heads, you probably have a much bigger issue. You should be completely safe to switch sides.
Old May 19, 2020 | 11:02 PM
magicdave2's Avatar
Engine: CFI 305
Thanks Chris!!!
Cheerio
Aug 29, 2019 03:59 PM
NCcowboy
Oct 14, 2011 12:22 AM
warrior_91
Jul 30, 2003 04:13 PM
nblanchard
Aug 5, 2002 09:37 AM
Js92RS
Oct 31, 2001 09:38 AM
