Lq4 Crankshaft Install
Old May 25, 2020 | 01:25 PM
Trollalot1's Avatar
Car: 1988 Firebird Formula
Hey guys, I'm on to installing my lq4 crankshaft. Can anyone help me out, I'm wondering what measurements need to be taken. I'm planning on using my old bearings which were good, would I be okay if I just torqued to spec without measuring clearances
Old May 25, 2020 | 01:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Lq4 Crankshaft Install
Why would you use old bearings?
Old May 25, 2020 | 01:47 PM
Trollalot1's Avatar
My old bearings were good, was just looking to replace the essentials.
Old May 25, 2020 | 07:58 PM
NoEmissions84TA's Avatar
If you are going to do that, then each bearing must go back to exactly where it came from.
Old May 30, 2020 | 10:09 AM
Trollalot1's Avatar
Yes, they will be
Old May 30, 2020 | 12:06 PM
GeneralDisorder's Avatar
Bearings are REALLY cheap. These are the kinds of decisions that lead to poor results. Especially if you aren't familiar with the tools used to take the measurements. You say they are "good" but then ask what measurements need to be taken..... so in actuality you don't know if they are "good" or not. These are the kinds of conclusions, based on conjecture rather than science, that will result in a failure. Don't assume anything.
To properly measure the mains and rods, you need a bore gauge, and micrometers. The first question is - do you have the proper tools? If not - either get them or consider taking the entire job to a professional.
GD
Old May 30, 2020 | 01:20 PM
OrangeBird's Avatar
Car: 1989 Firebird
GD
I had considered posting a very similar reply the other day when I first saw this thread , but then when I saw the user ID "Trollalot1" I changed my mind . Usually the question of whether to reuse bearing shells would be seen as an uninformed one , but with that user ID I wasn't sure if we were "having our chain pulled" as it were , so I figured best to just leave it alone ......
Old May 30, 2020 | 04:50 PM
I understand the conclusion you came to. I looked at his post count, join date, and recent posts before electing to reply. That was certainly an unfortunate user ID selection on his part but it looks like he's really just a noob not actually a troll.
GD
Cratemaster
Oct 28, 2007 02:50 AM
steve88iroc
May 7, 2004 10:51 AM
