prothane engine mount alignment issue
Old Jun 11, 2020 | 08:14 PM
Tidan's Avatar
Looking for suggestions on how to get my new prothane engine mounts to line up. The passenger side went smoothly but the driver side through bolt is off by about 3/16". I've tried unbolting the trans mount and jacking it up, loosening the mounts bolts to the K-member, standing on the engine, prying the engine in various directions, prying on the through bolt hole....I can get the bolt started from either direction but it hits the mount and won't go any futher - and I don't want to jack up the threads by pounding it too hard. Is it possible I somehow have the mounts incorrectly installed in the clam shells, e.g. are they side specific?
Passenger side:
Driver side - note the inner sleeve is off center with the mount:
Old Jun 11, 2020 | 08:58 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
Re: prothane engine mount alignment issue
When I did mime i was way more off than that just get the bolt and beat the bolt in with a big hammer
Old Jun 12, 2020 | 02:26 PM
Drac0nic's Avatar
Carbide burr would probably do what you need to do. Plenty of slotted swap mounts out there so I don't see why it'd be an issue here. Another thing you could do is if one side is good use a punch that has a taper on it to align the hole and force the bolt through.
Old Jun 12, 2020 | 02:30 PM
Tidan's Avatar
Coincidentally I pounded a tapered punch in the hole and left it over night and now the up/down alignment is good but the left-right is still off about an 8th. The deburr bit is next on my list of things to try. Thanks!
Old Jun 12, 2020 | 03:37 PM
Tidan's Avatar
BTW, does anyone know the torque spec for the though bolts? I torqued the bolts to the K-member at 34lbs but couldn't find a spec for the through bolt.
Old Jun 12, 2020 | 04:48 PM
NoEmissions84TA's Avatar
Are you able to loosen the clamshell to frame bolts just enough so that the mount can slide just enough to get the long bolt through? If it works, then go back and re-tighten those bolts for good.
Old Jun 12, 2020 | 04:50 PM
Tidan's Avatar
Thanks NoE, I finally got it this morning after letting it sit over night with a tapered punch pounded into it.
Now I'm just trying to find the torque settings.
Old Jun 12, 2020 | 08:31 PM
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
Engine mounts to engine torque 20-30 lbs-Ft
Engine frame mount to frame torque 20-27 lbs-Ft
Engine through bolt toque specs 45-60 lbs-Ft
These worked for me and i was using prothane mounts in original clams with an 088 block.
Old Jun 13, 2020 | 12:14 AM
Tidan's Avatar
Thank you 3rdgenzroc!
Shift06
Nov 14, 2009 12:12 PM
Mentor58
Feb 17, 2004 01:52 PM
Zepher
Feb 27, 2003 02:07 AM
zupmanZ28
Feb 21, 2003 11:18 AM
mystikkal_69
Jul 21, 2002 08:07 PM
