Spark plug wires with different resistance
Old Aug 13, 2020 | 02:57 PM
Firerat's Avatar
Car: 1992 Firebird with a Camaro Front
Engine: 3.1l V6 TPI
Hi all,
I had to replace one spark plug wire today because it was broken. I figured that my replacement has 4kOhms instead of 8kOhms like the others. All are 7mm.
Can this cause any problems? Should the resistance be the same for all wires? Car runs fine now.
Sorry if that's a stupid question, I'm a beginner..
Old Aug 13, 2020 | 03:03 PM
GeneralDisorder's Avatar
Re: Spark plug wires with different resistance
Doesn't matter in the slightest. The resistance is only there for noise suppression. 4k will do just fine.
GD
Old Aug 13, 2020 | 03:11 PM
Firerat's Avatar
Engine: 3.1l V6 TPI
Awesome, thanks for your response!
I'm super happy now as the car runs so much better and also proud I found the issue myself
Old Aug 13, 2020 | 07:27 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
4 THOUSAND ohms?? Sheesh! My spark wires are 270 ohms per foot...
Old Aug 13, 2020 | 09:10 PM
Vader's Avatar
Yes, 4KΩ. Many wires are rated to 2KΩ to 5KΩ per foot. It's not completely irrelevant, but nearly. It's what a friend of mine calls an "impractical truism" since it is so nearly irrelevant.
Ohm's Law is a physical law, not a theorem, suggestion, or guide. A little math with Ohm's Law will quantify the level of relevance. 30-40KV doesn't care one or two rodents' anteriors about a paltry little 4KΩ. The highly sensitive RF circuits in radios and TVs do, but certainly not the coil and not the spark plugs. The air gap of 0.060" is a LOT more resistive than 4K, or even 100K. Once the coil develops the voltage necessary to ionize the gap at the plug and create a plasma path for current flow, it's going to disregard a few hundredths percent additional resistance. That resistance will suppress any ringing, or secondary discharges, however, and that's just fine.
Old Aug 14, 2020 | 07:01 PM
rodents' anteriors
Or even their posteriors.
Old Aug 14, 2020 | 08:33 PM
Vader's Avatar
Rat-bellies are more susceptible to sensitivity, thus the metaphorical reference.
Old Aug 14, 2020 | 10:10 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Now THAT is the sort of information I come here to get!
Vinscully50
Apr 10, 2019 10:32 PM
bataradena
Jan 29, 2008 12:01 PM
transporter
Jul 4, 2004 08:36 AM
JMBoriss
Mar 26, 2002 11:20 AM
CamaroRS1990Guy
Jan 24, 2002 07:33 PM
