Im wondering if anyone has done this and can tell me what has to be done for the cars computer to read correctly and keep the car running right. I have a 1984 trans am 305 auto with the electronic quadrajet, the smog pump was disconnected when I bought the car and it would really make the engine bay a lot easier to get around if I could get rid of some of the emissions hoses. Any advice you have is appreciated.
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,454 Times in 1,874 Posts
Where sre you? what are the visual requirements for smog inspection?
I’m in Kentucky we are not required to pass a smog test
I have an 84 like yours. I removed the smog pump, air tubes... only the cat remains, which was replaced with a non-air injected one. The rest of the engine is stock, including the ccc carb. The car runs great and no check engine light. Just take your time and plug all vacuum lines.
Ok so what did you do with these plugs that are left and what exactly are they ?
NoEmissions84TA
close
- Join DateFeb 2017
- LocationMeriden, CT 06451
- Car84 TA orig. 305 LG4 "H" E4ME
- Engine334 SBC - stroked 305 M4ME Q-Jet
- Transmissionupgraded 700R4 3200 stall
- Axle/Gears10bolt 4.10 Posi w Lakewood TA Bars
- Liked:574 Times in 475 Posts
Those are for the air diverter valves.
DON'T CUT THE WIRES. You might regret it later. Or the next owner might.
Put some dielectric grease on/inside the terminals to protect them from corrosion and roll any unused wires up neatly. Use ty-raps to secure and tuck them away in an inconspicuous area. You might even want to slide the whole bundle into a plastic bag before you tuck them away.
Correct. I disconnected and kept everything just in case. Originally Posted by NoEmissions84TA
Those are for the air diverter valves.DON'T CUT THE WIRES. You might regret it later. Or the next owner might.
So im dealing with a 1984 Z28. and I wanna do the smog delete. IM in Necada and dont have to worry about the smog either. But im the new guy, and so is there any step by step that can show me exactly what I can remove?
