Fuel filler neck grommet installation?
Old Aug 29, 2020 | 02:41 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Transmission: TH-700R4
Axle/Gears: 2.77
I recently bought a new tank, fuel pump, fuel sending unit for my 89" Iroc. The tank didn't come with a filler neck so I had to buy another one. When I googled information on the tank and found this thread. link here. So I purchased the dorman 577-500 grommet that they talked about using to seal the neck and tank together with. But how do I put them together? What direction does the grommet go? Do I use a rubber mallet? Whats the best method? Twisting pushing down? I tried using silicone spray to push them together. It never went all they way through. Any help? I'm using Spectra Premium Fuel Tank Filler Neck Fn21 and gas tank 1AFGT00291. TIA!
Old Aug 29, 2020 | 04:44 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Fuel filler neck grommet installation?
https://www.thirdgen.org/forums/tech...ml#post5356234
Old Aug 29, 2020 | 05:45 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Axle/Gears: 2.77
Thats the same link I posted on my initial post
Old Aug 30, 2020 | 10:40 AM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Axle/Gears: 2.77
Ok so... the grommet (577-500) itself is for Chrysler and Dodge makes. So i figure a little modification might be understandable. Because its such a tight fit and I was unable to get it all the way through the hole. I turned the grommet inside out and started sanding the inside of it. Even after taking it down a bit, it was still really tight getting it in I used silicone spray to lune it up and get it in. I hope this information helps someone else in the future on this subject.
trafficlightguy
Carburetors
May 11, 2017 07:26 PM
BrianChevy
Apr 19, 2014 07:59 PM
jbenge
Apr 9, 2013 04:20 AM
elthomas
Aug 14, 2008 12:57 AM
DG
May 10, 2001 10:21 PM
