Vortec adapter for Weiand 6-71
Old Dec 15, 2020 | 08:00 AM
JuniorOne's Avatar
Car: Chevy SS Serie 2 ‘77 (69 nova usa)
Engine: 350 HO deluxe
Transmission: Tremec 500
Axle/Gears: 3.30
Hi! I have a chevy 350 HO deluxe engine with Vortec heads, anyone knows if an intake manifold to install a weiand 6-71 is in the market??
Old Dec 15, 2020 | 09:14 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Vortec adapter for Weiand 6-71
Like this?
https://shanonsengineering.com/produ...h-belt-satin-2
Old Dec 15, 2020 | 10:15 AM
JuniorOne's Avatar
Axle/Gears: 3.30
[QUOTE=aliceempire;6407021]Like this?
yes exactly like this one, but maybe I have to make more holes to fit the 8 bolts 6-71 has, the question is if the intake rectangular shape is the same as the 6-71
Old Dec 15, 2020 | 10:39 AM
I'm not well versed on it but I doubt it's the same or even close enough. If memory serves, weiand/holley discontinued 6-71 stuff shortly after the mini was introduced. And of those that were produced, I don't know if the vortec base was made. My guess is finding one means getting one from someones stash. GL
Old Dec 15, 2020 | 11:25 AM
JuniorOne's Avatar
Axle/Gears: 3.30
I think the same cause i cant find any adapter. And must be easier to find some heads and replace vortec ones.
Or sell 6-71 and change to a 142 for vortec. Thanks for your answers!
Old Dec 15, 2020 | 04:00 PM
Get a good set of aluminum heads and forget all about vortecs if you want that 6-71 bad enough. They'll flow more.
Old Dec 15, 2020 | 04:27 PM
JuniorOne's Avatar
Axle/Gears: 3.30
Which one would you recommend? Is there any head ready to install with all the parts assembled?
and also should fit the same shape of the intake manifold and water as the 6-71.
thanks a lot! And sorry for my english.
Old Dec 15, 2020 | 05:32 PM
There are a lot of good aluminum heads available. Looking for new? Best deal for the money is probably these https://www.airflowresearch.com/195c...cylinder-head/
Old Dec 15, 2020 | 06:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If these guys don't have what you're looking for then it probably isn't available.
https://theblowershop.com/
Old Dec 16, 2020 | 03:10 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
No there is not.. Any other vortec style pattern sbc blower manifold would need a custom made adapter plate to install a 6-71 roots blower on.
Find a set of large combustion chamber aluminum heads eg Brodix IK200.. eg Dart SHP 200.
Old Dec 16, 2020 | 07:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Wonder if you could buy the porter friendly base from rbs
https://www.rbssuperchargers.com/Pro...BDS--1100-0001
and modify the bolt pattern and port shape to cover the vortec heads?
Old Dec 16, 2020 | 12:29 PM
F-BIRD'88's Avatar
Dyers Blowers once had tenative plans to make a vortec pattern supercharger intake manifold for the
L-31 GM vortec/fastburn heads. Wether that actually got done you would have to ask Dyers directly.
You will be at or above the cost of new budget aluminum cylinder heads on this.
The AFR "Enforcer" As cast or Skip White NKB200cc, Assault racing "import heads" are very good for this.
topher1316
Nov 19, 2009 12:25 AM
JaggedJames24
Aug 21, 2009 03:15 PM
hotrod18_69
Feb 18, 2003 05:34 PM
TheLG4Whore
Aftermarket Product Review
Jun 12, 2002 07:27 PM
5.0GTA
Mar 11, 2002 09:28 PM
