383 Stroker water pump recommendations
Old Jan 11, 2021 | 10:33 AM
BRYDENGTA's Avatar
Car: ProCharged 1988 Trans Am GTA
Engine: 383 stroker with TPiS miniram
Transmission: fully built 700R4
Axle/Gears: late model 4th gen axle
Hi guys, I am currently building a new ProCharged 383 Stroker engine (Dart Block) to go into my 88 Trans Am GTA and I am trying to find the best water pump to go with my set up.
Will the standard Trans Am pump keep up with the engine?
Do I need high flow pump?
Any help and recommendations would be greatly appreciated
Old Jan 11, 2021 | 10:37 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 383 Stroker water pump recommendations
Stock works just fine but i tend to use aftermarket aluminum pumps.
Old Jan 11, 2021 | 11:01 AM
ULTM8Z's Avatar
Agreed on the stock pump.
It's usually the other parts of the engine/cooling system that are the culprit in terms of inadequate cooling. Too small a radiator, insufficient airflow (either due to blockage, too small a fan, no/incorrect fan shroud, etc), wrong thermostat, incorrect mix of water/antifreeze, too lean fuel mixture, too much timing, etc.
The flow is regulated by the thermostat anyway, so the pump mainly needs to produce good block pressure, which the stock pump is more than capable of.
Old Jan 11, 2021 | 11:52 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I always used stewart stage 2 pumps on my builds.
used them in my 383, 400” twin turbo, and now 555” twin turbo bbc. They always worked well for me but are somewhat pricey
i stayed away from electric ones after having one fail unexpectedly and another goin bad with alittle corrosion in the coolant system from sitting over winter. Pump was too sensitive to it and i was running mostly distilled water with water treatment and some coolant. But not totally 50/50 like most do due to concerns on the racetrack
Old Jan 12, 2021 | 09:53 AM
BRYDENGTA's Avatar
Thanks guys, it seems that the stewart stage 2 pumps get mentioned a lot so I shall look into them I think.
Old Jan 13, 2021 | 12:16 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have a Flowkooler pump on my Vortec 383 in my Express van. Very happy with the way it cools even with the travel trailer behind it combined with a 34x19x2-5/16 core aluminum radiator and dual 16" Flexalite flex wave fans on a proper shroud. Has a march 25% underdrive crank pulley and the march water pump pulley is slightly larger than stock too. Water pump is about 30% underdriven. I know a 3rd gen will never fit a radiator that size but its also not having to cool a ~500 hp engine moving around 12,500 lbs.
With the stock belt ratio the stock pump worked fine but it ate alot of power. With a stock pump and underdrive it cooled fine while driving even towing but would heat up a bit with the a/c on idling around town at slow speeds (~210°F). The Flowkooler + Underdrive stays right at 180°F and still saves alot of power compared to the stock belt ratio and pump. The Flowkooler pump is basically a stock pump with a high efficiency billet impeller.
Old Jan 13, 2021 | 08:33 AM
ULTM8Z's Avatar
Are you saying you actually felt a seat of the pants gain in power (or rather, reduction in water pump power consumption)?
Old Jan 13, 2021 | 06:41 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Runnin Stewart here as well, with be cool radiator. Soo far soo good. Aluminum surprised me how light it was
Old Jan 14, 2021 | 07:44 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Stock rad with a cheap electric water pump (proform I think)
Stock rad fans as well
Street driven...
Old Aug 31, 2025 | 05:26 PM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
Old Aug 31, 2025 | 07:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Why respond to an old post ?
Reddeath210
Jul 1, 2020 01:57 PM
88gunmetalgta
Mar 20, 2011 06:04 PM
383HSR
Apr 24, 2009 11:39 AM
ShaneBuss2
Aug 27, 2002 01:31 PM
gregz28
Dec 21, 2000 03:18 PM
