Need some advice on heads
Old Jan 27, 2021 | 11:05 AM
hindsey123's Avatar
I have a few sets of heads to choose from none of them are great I do understand there are many better options but this is what my current budget allows with that I just am looking for some advice on what ones to use what I have available are 882, 415 ( not 416 they are 53cc 415) 624 and 339x i was told to use the 415 heads all the others are 76cc i have a eps performer intake 650 edelbrock thanks in advance for the help
Old Jan 27, 2021 | 11:59 AM
Re: Need some advice on heads
What size motor? What kind of car? What's the intended use? What cam? What pistons (i.e. what kind of compression are you going to end up with)? Exhaust? Converter? Gears? Why no decent choices, just a bunch of bottom-of-the barrel crap smogger stock heads in the first place?
Old Jan 27, 2021 | 12:22 PM
hindsey123's Avatar
Motor is a l48 350 the car is a 84 firebird intended use is a summer and fall car street use no tracks will ever been seen by it has flat top pistons 40 over has eps performer intake 650 edelbrock carb and cam depends on the heads I choose and why choose one of the ones I listed is because that is what I can afford for now like I said I know there are may better options out there but these are what I have to work with for now
Old Jan 27, 2021 | 12:48 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Of all those choices I would pick the set not cracked and in best shape I guess but then you get to waste money on a second set of gaskets when you install proper heads.
Just sit on it and wait until you can afford something proper nothing worse than buy twice cry once
Old Jan 27, 2021 | 12:59 PM
I'd recommend waiting another paycheck or 2 and getting something decent. No sense in shooting your whole wad on a bunch of garbage, then being no better off than you are now and in fact WORSE OFF because now your wallet is empty.
882, 624, and 993 are common on L48. Of course you don't have a "L48"; those didn't come .040" over or with flat tops, and just about any motor that IS .040" over, is no longer the same as any L anything. Might be close or might not. But even at that, a .040" motor is usually a "rebuilder special" (wouldn't go .030" so they punched it out 1 more) and is therefore likely to have crap like 614, 882, etc. on top of it. I'm gonna guess then that the "cam" is a 929 replica, as would be typical in such a situation. (and would have been the stock one in a L48 for that matter) Keep in mind that virtually any .040" over "flat tops" will add the usual .020" of extra "rebuilder" deck clearance, meaning they're now most likely somewhere around .050 - .060" down in the hole at TDC.
Keep your money in your pocket until you can spend it in some way that actually accomplishes something.
Old Jan 27, 2021 | 01:05 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
882s , get a cheap Summit K1103 cam it will be a decent cruiser. Save up some $ for Vortecs in the meantime.
Old Jan 27, 2021 | 01:26 PM
ANY of those only if they're free, the gaskets are free, the fluids and whatnot are all free, and labor is free.
Otherwise, if it costs even ONE CENT, keep your money in your pocket, and save up for something decent. Vortecs being the obvious goal here.
EVERY DIME you put into that GARBAGE, moves you FARTHER from something good. Delay your instant gratification of "doing something even if it's useless" in favor of ACCOMPLISHMENT a little further down the road.
Old Jan 27, 2021 | 03:09 PM
hindsey123's Avatar
What about 187 062 or 185 the 062 are a better head than any i have asked about so far correct
Old Jan 27, 2021 | 03:45 PM
062 is 96-2000 Vortec. The other casting # for them is 906.
Those require a different intake.
They are indeed the ones to get, in 2021. Keep your money in your pocket until you are prepared for those.
187 is TBI monkey excrement. 185 is 307 2-bbl stuff; elephant plop. (big difference there between monkeys and elephants, right?)
Old Jan 27, 2021 | 05:31 PM
hindsey123's Avatar
Thanks for the help I can get a set of the 062 for 50$ ready to go tomorrow from a friend with a intake
Old Jan 27, 2021 | 07:07 PM
Everybody should have friends like that. Why don't I have any?
82z-28/92Rs
Sep 13, 2014 03:44 AM
K88-79
Feb 23, 2011 06:42 PM
IZIBAKEMIZI
Oct 21, 2010 12:01 AM
330hp_91RS
Jun 23, 2003 11:12 PM
