1991 firebird 305 egr issues
Old Feb 28, 2021 | 11:12 AM
Warlocksirix's Avatar
Car: 1991 Firebird Trans Am
Engine: 5.0L 305 TPI
Transmission: 4S Auto
I have done searches through the forum and Google and keep finding egr solutions. I have an egr and get the egr code when driving on the highway it's a soft code. My issue is my egr and the PO egr were just vacuum and no wire connection, also no matter where I look I can't find a solenoid pigtail or vacuum lines to one. Am I missing something with the 1991 305 tpi and how the egr works that is different than all the posts I'm finding.
Old Feb 28, 2021 | 11:20 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1991 firebird 305 egr issues
No snipped wires next the the ignition coil ?
starts from e9 at the ecm a grey wire and a black ground.
Old Feb 28, 2021 | 11:26 AM
The only 2 vacuum lines back there go into the firewall.
Nothing looks cut or fabricated on the harness. And the only pigtail back in that area goes to the map sensor. Everything else looks factory
Old Feb 28, 2021 | 11:35 AM
Engine: Lb9
Transmission: M20
The lines that went to the egr solenoid started under the drivers side of the throttle body. To the egr solenoid then from solenoid to egr. Have to pull the plenum to install properly.
if you in a non emissions area just do a reprogram of your chip to delete the function and 32 error.
Old Feb 28, 2021 | 11:36 AM
Engine: Lb9
Transmission: M20
those lines are for hvac and heater control valve.
Ok I found the solenoid (it was sitting under the distributor against the engine) and I happen to pull one from a scrap yard with pigtail. Will this work for the tpi? It was off a 92 tbi
Old Feb 28, 2021 | 11:44 AM
Engine: Lb9
Transmission: M20
If normally closed should work
Old Feb 28, 2021 | 11:46 AM
Thanks for the help I thought it was near the map sensor didn't even think to look near the harness at the back by the distributor.
Old Feb 28, 2021 | 11:47 AM
Engine: Lb9
Transmission: M20
Should be sandwiched between the coil bracket if you had the right bracket/solenoid.
Old Feb 28, 2021 | 11:50 AM
The one I picked up has a bracket so hopefully it'll be useful then all I need is new vacuum lines
Old Feb 28, 2021 | 12:00 PM
Engine: Lb9
Transmission: M20
DORMAN 47418 Tubing Dia.: 5/32" or soft rubber line will work.
if you find the original connector much cleaner to unpin and use the other connector instead of cutting and splicing. Listle has a tool for terminal release or a round release tool is cheap on eBay.
Old Feb 28, 2021 | 12:02 PM
Engine: Lb9
Transmission: M20
https://www.ebay.com/itm/Delphi-Pack...4AAOSwgotcR13F
Old Mar 2, 2021 | 07:20 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
When I had code 32 on my TPI it only triggered at highway cruising speed and was exactly as you described being a soft code with no other issues other than the CEL coming on. I went through the entire system and what cured it was a new EGR temp sensor, only issue is its not made anymore for F bodys but you can get one from several Corvette parts places on eBay. The only difference between the parts is the Corvette one has a much shorter wire so you have to splice into the original.
Old Mar 2, 2021 | 08:50 AM
Engine: Lb9
Transmission: M20
Gm finally got smart in 90-92 the egr didn’t have a temp sensor.
Old Mar 2, 2021 | 08:58 AM
Engine: 5.7 L98
Ahh, good catch. OP should be good to go then
mcb55-210
Sep 9, 2020 06:01 PM
rick89formula
Jul 20, 2007 12:11 AM
Darkshot
Jul 1, 2007 09:13 PM
KnightConvoy
Jan 4, 2005 10:24 AM
camaro1952
Aug 23, 2002 10:51 PM
