engine rpm failure
Car: Pontiac Firebird gta 1987
Engine: 5L7 TPI
Transmission: Automatic
engine rpm failure
hello everyone I am french and I transcribe with google translate I have a 1987 GTA Pontiac 5l7 TPI L98 engine, here is my problem: when my engine is hot I cannot exceed 1500/2000 rpm when I drive my vehicle , but when my car is in neutral on park or on neutral it rises well in rpm up to 4000 rpm I change the temperature sensor under the plenum, the injection pressure regulator, flowmeter air mass, ignition advance control regulator, distributor, injectors and the fault is still present, an idea to help me out ... Thank you
Re: engine rpm failure
I wasn't able to pass 3000rpm for quite a while in drive, but in neutral I could slowly rev past 3000... it ended up being a blocked catalytic converter. Revs fine now. Perhaps disconnect your cat and go for a drive, see how it goes.
Engine: 5L7 TPI
I removed all the inside of my catalytic converter so it doesn't come from that, but thanks for answering And since it's a th 700 auto gearbox, I can't put myself in neutral while drivingLast edited by frenchpontiac; Apr 3, 2021 at 04:43 AM.
Engine: 5L7 TPI
hello, the ignition is ok 6° BTC (0.6.00) but for the fuel pressure I do not have the material to test, but my fuel pump is new, I have removed the main fuel supply pipe and running the pump without starting the engine there is a lot of pressure but, I will try to find a pressure gauge to control. But how much should the pressure be? . I have another question I know that we can control the system errors by putting an electric cable in the OBD socket which is under the dashboard but I do not know how to do it? In any case thank you for your it's nice
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
You can pull codes by inserting a paperclip, or something similar... (conductive please...) into the top right two pins on the ALDL connector. (shorting them together.) Turn the ignition On, (don't start the motor) and then you can count the flashes of the check engine light to get the codes.
Engine: 4++,350 & 305 CIs
I would test the coil output and fuel PSI
Engine: 5L7 TPI
I have a stupid question: when you change the injectors, you have to (code) reprogram or save a code for the injectors? Thank you Last edited by frenchpontiac; Apr 8, 2021 at 10:43 AM. Reason: traduction
Engine: 5L7 TPI
Hello, I live on an island and no one is able here to update my ECM again I have to do it alone but I will order a pressure gauge to check my gasoline pressure which can provide me with a good address to have the right mano and the right threading Thank you
my87_5spgta
Dec 3, 2014 09:13 PM
