Not Getting Gas
Old Jul 11, 2021 | 01:34 PM
rjfs's Avatar
Not Getting Gas
I am restoring a 1989 CAMARO R/S with a 305 TBI engine. I have installed a new gas tank, new fuel sending unit, new fuel pump, new fuel filter and two rebuilt throttle body fuel injectors; however the fuel system is not delivering gas to the engine. I checked power at each injector using a NOID light and the light flashed when cranking the engine so it appears they are getting power. It seems fuel is getting to the TBI assembly but not through the injectors into the engine. I can pour gas into the throttle body and the engine will run for a few seconds then die so I’m nearly certain it would run if it got fuel. As I mentioned, I replace both injectors so I don’t think they are the problem. What else could be the problem?
Thanks for any and all help.
Old Jul 11, 2021 | 01:39 PM
BytePaul's Avatar
Transmission: ...was received.
Re: Not Getting Gas
did you check fuel pressure to be certain? fuel pump relay?
Old Jul 11, 2021 | 02:54 PM
rjfs's Avatar
Re: Not Getting Gas
I'm not certain how to check the pressure. I don't think there is a port on the fuel line to connect a pressure gauge on this engine. How do I go about checking the pressure?
I do believe the relay is working since I can here the pump fire up when I turn the ignition on.
Thanks.
Old Jul 11, 2021 | 03:48 PM
BytePaul's Avatar
Re: Not Getting Gas
Disregard this information. N/A
Old Jul 11, 2021 | 03:54 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Not Getting Gas
Did you put a new fuel pressure regulator membrane in the fuel pressure regulator ( part of the TBI unit) ? May want to look there. And that picture of a TPI engine shows something that does not exist on a TBI
Old Jul 11, 2021 | 03:56 PM
BytePaul's Avatar
Re: Not Getting Gas
oh, he did say tbi. sorry about that! that's why i usually keep quiet. lol
Old Jul 11, 2021 | 06:35 PM
rjfs's Avatar
Re: Not Getting Gas
No, I didn't do anything with the fuel pressure regulator. I checked on how to rebuild it and it looks pretty easy so that will be my next step. Thank you very much for the suggestion. That might be the key. I'll let you know the results. Thanks again.
Old Jul 11, 2021 | 06:39 PM
rjfs's Avatar
Re: Not Getting Gas
It is a TBI and not a TPI but I certainly appreciate your suggestion. It looks like Chevy had both in play around this time and it does get confusing. I'll keep your suggestion on file for future reference. Thanks again.
Old Jul 27, 2021 | 01:16 PM
rjfs's Avatar
Re: Not Getting Gas
I replaced the fuel pressure regulator membrane in the fuel pressure regulator and that did the trick.
The engine now starts with just a couple cranks and idles very well. Thanks for the advice henryd3. That was exactly the problem. Thanks again.
Old Jul 27, 2021 | 02:27 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Not Getting Gas
Cool, glad I could help. Have fun!
19CAMARO85
Nov 15, 2014 06:07 PM
Jamescamaro90
Nov 14, 2009 06:23 PM
91camaroguy
Apr 13, 2009 05:19 PM
tmorris71
Dec 29, 2007 12:35 PM
grafx
Dec 19, 2001 08:26 PM
