What do you use as modern vacuum lines?
Old Aug 9, 2021 | 03:56 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hi,My engine is a stock 1986 tpi 305I'm planning on replacing the old broken plastic vacuum tubes, rubber connectors and hoses, but I guess modern vacuum lines are used today to replace the outdated plastic tubes that GM used in the 80s.
For this reason, I ask for your help in deciding the best current solution alternatives for vacuum lines.
Thanks in advance,
Old Aug 9, 2021 | 04:36 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: What do you use as modern vacuum lines?
I would use this site to look up part numbers for the plastic stuff to replace:
http://www.austinthirdgen.org/parts/html/main1.htm
I measured the ID of the hoses that needed replacing with digital calipers, then went to my local auto parts store and told them how many feet of it I needed.
Old Aug 9, 2021 | 05:03 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
I use regular vacuum hose; the same that has been used for the past 50 years or more...
Old Aug 9, 2021 | 06:03 PM
NoEmissions84TA's Avatar
Old Aug 9, 2021 | 06:21 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Same, regular vacuum hose worked good for me when the old stuff got brittle and started to break.
Old Aug 10, 2021 | 09:17 AM
Denis.V's Avatar
Axle/Gears: No idea
But, common rubber hoses or special silicone hoses?
(some e-bay chinese silicone hoses collapse with the engine vacuum. Hoses having thick walls are required )
Old Aug 10, 2021 | 09:28 AM
T.L.'s Avatar
Regular rubber vacuum tubing...
Old Aug 15, 2021 | 06:57 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Tygon works great and it comes in a pretty yellow color.
SRKLEGIN
Mar 6, 2017 05:55 PM
92Birdofprey
Mar 23, 2009 04:09 PM
84_berly_84
May 27, 2004 05:59 PM
