Check engine light won't return codes
Old Oct 14, 2021 | 12:26 AM
Jack_88's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 TPI
My check engine light on my 1989 5.7 TPI equipped car is on and it's running weirdly but when I jump the pins to read the codes, it won't blink consistently. The length of the blinks and time between them is inconsistent, it won't spit out the 12 code at the start or any time. I can't seem to find anything on this happening anywhere, I'm worried it's a computer issue, but I'm not sure how to proceed on diagnosing it.
Old Oct 14, 2021 | 01:01 AM
vorteciroc's Avatar
Top Answer: 1
Re: Check engine light won't return codes
It is not supposed to be consistent.
If 12 is the only number currently set, the indicator light behavior will be:
-Blink
-Short pause
-Blink, Blink
-Long pause
-Blink
-Short pause
-Blink, Blink
-Long pause
-Blink
-Short pause
-Blink, Blink
-Long pause
Essentially:
-1
-pause
-2
-End
This behavior is displaying Number 12.
Repeated two more times (making it three times in a row).
Each DTC Number currently set, will be flashed Three times before flashing the next DTC Number.
Here is a video of someone displaying DTC Number 12:
Old Oct 14, 2021 | 01:06 AM
Jack_88's Avatar
Engine: 5.7 TPI
I appreciate the response, but I understand how the OBD I is supposed to function, I've had the car 11 years and used it before. When I say it's being inconsistent, it's that the length of time the light is illuminated and extinguished follows no discernable pattern, certainly nothing that follows any code. There seems to be 3 or 4 different lengths of time of the blinks and just as many different gaps between the blinks. When the pins aren't jumped, the light remains solid, as it's supposed to.
Old Oct 14, 2021 | 03:25 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Is the battery fully charged?
Old Oct 14, 2021 | 10:48 AM
Jack_88's Avatar
Engine: 5.7 TPI
The battery is fully charged, the engine cranks quickly and fires right up. The idle surges from 700rpm to 1500rpm before leveling off to 800-1000rpm after warming up a minute or so. I can guess a few things about that aspect of it, but the CEL behaving so oddly is baffling. I'll check the grounds, but beyond that, the ECM is the only thing that comes to mind. I don't like throwing parts at a problem.
Old Oct 14, 2021 | 04:08 PM
vorteciroc's Avatar
Top Answer: 1
Please Post a video of the behavior.
Old Oct 14, 2021 | 05:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
At the ecm ground a9 white/blk wire . If the mil doesn’t flash I’d say it’s bad.
the lack of communication from the ecm is a sign of a bad ecm. Can take a screw driver handle and tap on ecm case while running and see if running changes this flexes the circuit board another test to see if ecm is bad.
Old Oct 14, 2021 | 05:06 PM
Jack_88's Avatar
Engine: 5.7 TPI
It isn't doing the 12 code nor does it repeat any other code. It makes what looks like might be codes but it's not functioning at all like normal.
Old Oct 14, 2021 | 05:12 PM
Engine: Lb9
Transmission: M20
Check code koeo, your in field service mode
Old Oct 14, 2021 | 05:30 PM
OrangeBird's Avatar
Car: 1989 Firebird
https://youtu.be/SeYTf1NWSUE
Yep, what tuned said, , , ya gotta have the key on with the engine NOT running for it to properly blink out the codes
Old Oct 14, 2021 | 11:50 PM
Jack_88's Avatar
Engine: 5.7 TPI
Ah, yes, as usual, the answer seems to be I'm an idiot who forgot an obvious thing I'd previously done right for years. I'll check on it tomorrow and see what secrets the ECM has to share.
Old Oct 15, 2021 | 12:08 AM
vorteciroc's Avatar
Top Answer: 1
Please.
I am truely interested to see the abnormal behavior that is occurring.
I have seen incorrect flashing years ago... and would like to compare what you have going on.
Old Oct 15, 2021 | 05:11 AM
OrangeBird's Avatar
Car: 1989 Firebird
Hey no biggie, it's an easy mistake to make, and it sure beats having replaced the ECM only to find out later that the engine running was the cause of the odd CEL activity
Please.
Hi Vorteciroc, Jack posted a link to the video in post #8, in that video the odd behavior is seen (and that's how Tuned and I saw that he had the engine running during the code reading attempt)
Old Oct 15, 2021 | 07:18 AM
Engine: Lb9
Transmission: M20
https://www.motortrend.com/how-to/14...ally-speaking/
jimmomo
Oct 20, 2021 05:29 PM
evilemokid94
Oct 27, 2010 12:48 PM
Welsty2003
Oct 3, 2005 06:46 AM
DrDuke
Jul 22, 2003 05:12 PM
BlackZee
Jun 13, 2001 06:17 PM
