New cam install, lifter question
Old Dec 19, 2021 | 09:58 AM
theraymondguy's Avatar
Sbc ​​​Nube installing cam and lifter kit, lifters are new in box - no cleaning or soaking.
Doing what I can with inspection to ensure smooth break in.
I noted most most of the lifter plungers mover freely when depressed, however some are very stiff - to the point where I cant really be sure if they are moving.
is this typical? Are the stiff units si,ply "pumped up"
thanks for your replies.
Old Dec 19, 2021 | 01:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: New cam install, lifter question
Throw all the lifters in a container of engine oil until you are ready to use them.
Install cam with lots of assembly lube
Install lifters and reassemble engine.
When you're ready to start the engine, run it up to different rpms for about 30 minutes.
Change the oil and filter
Change the oil and filter again after about 500 miles of driving
Change oil and filter every 5000 miles after that
Old Dec 19, 2021 | 01:42 PM
Yes it is typical.
I typically soak lifters for a day or 2 in lacquer thinner and then take them out and let them drain, turning them upside-down about half the time. That'll get the assembly grease (cosmoline, whatever) out of em. Then you can soak em in oil for a day or 2 to render them somewhat consistent.
Of course, there are ANY NUMBER of web sites that caution STRICTLY against soaking lifters. Now granted, I'm an idiot and a moron and the stoooopidest blob of protoplasm to ever haphazardly splatter uncontrollably onto the surface of this miserable planet (just ask my children, they'll tell it to you straight); but somewhere in the back of my mind that is only made up of 2 brain cells that do NOTHING other than fight with each other over control of the ... immediate destination of the little head, I am forced to ask: WHAT THE HELL is going to happen to those lifters AFTER they're installed and operating? So what can POSSIBLY be so bad about THE SAME THING happening to them BEFORE installation?
Do the math. Soak em in thinner, then soak em in oil, then come back and report the results.
Old Dec 19, 2021 | 04:58 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Nothing wrong with soaking them. It's just not absolutely necessary. You want a good coat of oil in the lifter bores and on the sides of the lifters, with assembly lube on the cam lobes and lifter faces. They are NOT supposed to be pre-pumped before performing rocker arm adjustment. 'Seems to me that all the lifter plungers should move the same amount. I'd call the manufacturer and ask them. Make sure they didn't mix in a couple of short-travel plunger lifters (like Comp Cams Magnum) with a standard-travel set (like Comp Cams High Energy)...
Old Dec 19, 2021 | 05:30 PM
Thank you all, I'll take sage Thirdgen advice over Google knowledge any day of the week.
It's coming along. The cam gets swapped on Wednesday. Still some cleaning and maybe even some painting to be done.
Old Dec 19, 2021 | 06:09 PM
T.L.'s Avatar
What cam? What induction? Just curious...
Old Dec 19, 2021 | 07:30 PM
Lunati 420/443 112 lsa
Edelbrock performer 2101
Quadrajet (Canadian OE non ccc)
Accel distributor
700R4, soon to be 3.42 auburn (currently 3.27 9 bolt one legger with a worn diff).
The carb and distributor are dialed in (or they were lol). The intake has no egr provision, I plan to block off the exhaust cross over as its a summer only car. The cam is similar to edelbrock 2102, summit 1102, Melling M select.
Old Dec 19, 2021 | 11:20 PM
T.L.'s Avatar
I finally read your first thread. That's a great-looking car...
Old Dec 20, 2021 | 09:36 AM
I think you're being a bit too generous here. It's ABSOLUTELY IDENTICAL IN EVERY WAY to those other cams. It's #1 in the old familiar series that came out in the 70s, back before you could get anything like a modern valve spring. The 204/214 that you have was targeted toward 300-ish CID engines, the 214/224 for 350-ish, 224/234 for 400-ish, and 234/244 for 450-ish ones. There was also a 194/204 selection that was marketed alot like the "truck torque" cams for 4.8 are today. Alternatively, the progressive steps were often called things like "Stage 1" for your 204/214, "Stage 2" for the next, etc. Over time, different vendors have offered the same lobes ground on various LSAs, usually anywhere from 110° to 114°, 112° was probably the most common. The "Stage 1" is familiar from Edlebrock as the "Performer", and the "Stage 4" as the "Performer RPM". A few mfrs have offered single-pattern versions of them; usually the 204 or 214 on both lobes. I can't recall ever seeing the 224 or 234 that way, butt somebody more than likely has.
That should be a decent enough cam as far as that goes; not gonna set the world on fire or anything, or be particularly competitive with any more modern designs, but will be easy on the valve train (given its very gentle ramps and very low lift), and give better power than stock, with very little "too much cam" issues. Will work fine in a 350 with a stock converter. Will still be OK for that if it's a 305. If it's a 350, and the compression is above about 9:1, it may cause trouble with pinging. Needs (or at least benefits from) better than stock springs; the "Z28" springs, any of the cam mfrs' entry-level 1.25" dia product like Comp 981, or LS6 springs with the Comp "adapter" retainers 787, will work fine.
Old Dec 20, 2021 | 03:30 PM
T.L.'s Avatar
I have the next step up in that series from Lunati in my small SBF (214/224, .472/.496, 112° LSA). It's the SAME cam as the Edelbrock "Torker" cam. Where I screwed up is going with the 112° LSA, as the SBF likes a tighter LSA (like 108°).
I went with a 212/218 and 110° LSA in my 350...
Old Dec 21, 2021 | 05:30 AM
This ^ is why I chose this grind. My wife chides me about never letting her drive the car. For that to happen comfortably it has to have enough brakes to reverse time or -
At least the front axle LS conversion along with the 11.5” rear discs that come with the 3.42 axle -
I’ll be glad to have her drive it after that, but until then I want all the engine vacuum I can get so I don’t have to supplement with pucker from the passenger seat.
The Melling version has a 110 LSA and a surprisingly high price tag. RockAuto is the likely Melling parts vendor for Canadians, they’ve had very poor inventory of Melling 817 lifters over the pandemic.
I purchased the lunati cam and lifters for $166 shipped (CDN), vs Summit K1102 $198 plus shipping & brokerage fees, RockAuto Melling cam $129 + 70.72 sealed power lifters + shipping (no brokerage / thank you RockAuto!).
I got the lunati kit at that price by ordering it from Amazon Canada when the kit was unavailable, guaranteeing the old price upon delivery. Smart guy right? Until I forgot all about it and 3 months later my wife called wondering “what I bought now?!?”
It’s now a $200 cam kit from Amazon.ca
I’m going to break it in on the 100k mile springs, then make a change to the z28 (vs739r) springs. I’m using a Melling stock replacement timing set (as noted, gentle ramps, no need for the additional drag/mass of a double roller), so they’ll be a good fit.
Old Dec 21, 2021 | 05:36 AM
Thank you, it’s older paint but still looks good from 10’ and beyond.
As above, I’m all about that 22inHg life. I might do the 4th gen master and booster as well - if the reservoir didn’t look like something from the Jetsons I’d have already done it.
Old Dec 21, 2021 | 05:55 AM
Yes it is typical.
I’m a bit ashamed to admit it, but I called Lunati at lunch yesterday (on the company cell phone, so at least I didn’t pay for the call):
They confirmed it is typical - the “grease” they use in assembly is water based (EPA compliant), it does evaporate off and can leave the lifters bound up.
They recommended Seafoam to clean/rinse the lifters (epa compliance?), and then soaking in sae30 or break in oil.
Thanks again for the thoughtful (and entertaining) response. Fwiw, if you’re kids don’t believe they know more than you, what have you accomplished?
I've never used thinners before, it stinks like crazy. All right to put the thinners and lifters in a plastic container to soak?
Old Dec 21, 2021 | 02:19 PM
T.L.'s Avatar
'Not trying to rain on your parade, but Sealed Power has had major quality problems with their lifters lately (as well as Comp Cams).
I'd hate to see you round off your new cam after all that work...
Old Dec 21, 2021 | 05:02 PM
Yes, that's what I'd gleaned from a source or two myself.
I got my lifters from lunati with the cam. I didn't want to go with sealed power from rockauto, I was holding out for the melling lifters.
Old Dec 21, 2021 | 05:50 PM
Gordon G E's Avatar
Car: Got me a nice little '86 Z28.
Engine: A brand new 350 with a forged lower
Transmission: 5 speed, TKO600.
Axle/Gears: 10 bolt 373 modified zexel.
Clean them with brake cleaner then soak in oil for at least 1 hour before install. I ALLWAY'S use a pump oiler and pump oil into the side hole on the lifter until I see oil in the plunger area where the push rod end goe's. Befor you install the cam it is very important to use ALOT of assy. lube on the cam lobes. Both sides. Open ramp and close ramp and bearing surface's. Every cam failure has been due to lack of lube. That is why you run the engine at 2000 RPM for 20-30 minutes on initial (first) start. Lunati cams are a quality piece and done properly should provide a long life. Of course perform the recommended cam lash adjustment before running. You tube has proceedures . Good luck. BTW, I am 66 yrs.old and been wrenching since I was 8 yrs.old.
Old Dec 21, 2021 | 09:03 PM
T.L.'s Avatar
That is not entirely true. MANY cam failures over the past decade have been due to DEFECTIVE or poor quality components.
I know people who have followed the proper procedures TO THE LETTER and still rounded the lobes and chewed the lifters into carnage. Fortunately, I haven't lost a flat-tappet cam yet (but I've done only 3). Rocker arm adjustment for hydraulic cams is supposed to be done "dry" (ie: lifters not pumped up). Soaking them is totally unnecessary but won't hurt a thing. A quick dip in oil before inserting them into their bores is as effective as soaking for an hour...
Old Dec 21, 2021 | 09:28 PM
T.L.'s Avatar
Okay, good. I thought you got the Sealed Power. For my first cam swap, I used Melling lifters on a Comp Cam. Never had any problem with them, and they were half the price of Comp Cams (of course that was 14 years ago, so who knows what the quality is now?). Did the opposite for the second cam; a Lunati with Comp Cams lifters. That was 2016 and so far no problems. My 350 in the Firebird has a Comp Cam & lifters that I bought in 2002 and sat in their boxes until I was ready to use them (which was 2020), so they are from a time before the quality problems started, HOWEVER I am convinced they sent me their "Magnum" lifters instead of the "High Energy" lifters, because anything more than 1/8 of a turn past zero lash was hanging valves open. I should have been able to go 1 full turn without any problem, but nope. 'Tried 3/4, 1/2, some were still hanging open at 1/4 turn. And no, I wasn't going past zero lash before adding preload. No "spinning the pushrod" and waiting for resistance. Only up & down movement until the movement just stopped. Has to be short-travel plunger lifters. 1/8 seemed to do the trick, and there is no clatter or ticking noise. It's just not something I ever would have thought to check before installing lifters...
Old Dec 22, 2021 | 07:48 AM
I appreciate you looking out for me T.L.,
I’ve had heads off of sbc previously, even iron dukes (industrial versions not auto) but this is my first effort with lifters / cam so I’m likely to make mistakes if I’m not told otherwise!
Soup’s done!
there is a notable yellow tinge to the thinner. Time to dry them out.
Old Dec 24, 2021 | 06:58 AM
Old Dec 24, 2021 | 10:56 AM
T.L.'s Avatar
You've been busy...
Old Dec 24, 2021 | 12:03 PM
skinny z's Avatar
....as the SBF likes a tighter LSA (like 108°).
For the record, like the SBC, the LSA would revolve around the CID and the cylinder heads used.
As a rule of thumb, smaller displacements with a given head can use a wider LSA than larger displacements.
Improve the heads (such as going to a 2.02 intake from a 1.94) for a given displacement and the LSA can be broadened as well.
The critical value though is overlap.
Old Dec 24, 2021 | 12:06 PM
skinny z's Avatar
Good luck on the break in.
It always made me a little nervous when I was running a flat tappet. Successful though.
Old Dec 24, 2021 | 03:54 PM
You've been busy...
Ive done top end work on industrial engines, no one cares what the finished product looks like so it takes no time to finish by comparison. Wire wheeling, cleaning, more wire wheeling, primer and paint add so much time. I’d be ashamed if I were on the clock for this one.
Nervous? To quote Ruby Sue from Christmas Vacation - “Sh@&$!!in bricks”.
There’s a whole bunch of new parts all merging together hopefully successfully in one heat cycle. I’ve done all I can, everything that isn’t lifter or cam lobe got permatex assembly lube. Lifters and lobes got every spec of lube from the supplied packet. Lunati recommends the driven br30 break in oil, I’ve got 5 fresh quarts at $75 CDN and I’ll be priming the system prior to start up.
I’ve got no choice but to run coolant in it (The Hoth rebel base is our twin city), so I’m considering leaving the burp funnel on the rad / just leaving the system open and running the (dual tpi) fans full on from start up.
Old Dec 24, 2021 | 06:12 PM
T.L.'s Avatar
Yeah, that Lunati lube is weird looking.
You don't need break-in oil. It is non-detergent oil for new engines that need the rings to seat quickly. . It's actually not the best motor oil. Comp Cams loads theirs up with 3,000 ppm of zinc, which is double the amount you need. 'Might as well use it since you already have it. Driven products are good. Just prime the oil pump before you fire it up...
Old Dec 26, 2021 | 09:22 AM
skinny z's Avatar
...just leaving the system open
I think you'll find that after about 10-15 minutes of elevated RPMs for break-in that you'll have a rad that's boiling over.
One start up I had blew a rad hose about half way through. Had to shut it down and make a repair. The cam survived but I learned it doesn't take long to build a lot of engine heat.
Old Dec 26, 2021 | 04:02 PM
NoEmissions84TA's Avatar
Old Dec 26, 2021 | 06:20 PM
T.L.'s Avatar
Yeah, don't leave the cap off. Let the overflow tank do its job, and use a thermostat that has a small hole drilled on the side to allow air bubbles to escape. You can buy them with that feature (like I did), or drill your own...
Old Dec 26, 2021 | 06:58 PM
Thank you, I’ll go ahead and add a vent to the thermostat.
Some more today. Balancer, fuel pump, valve adjustment, engine oil primed.
Old Dec 26, 2021 | 07:19 PM
Advance the timing "too much". It'll help keep the temps down during breakin. And of course, it won't be under any load then anyway, so you don't have to worry about pinging.
Old Dec 27, 2021 | 06:02 AM
This is a most interesting point. I’ve read / heard that timing should be 30/40* during cam break in - This is likely why (40*).
I had timing at 34* all in, 3200 (the next heavier set of springs had it in at 3800), I’ve got a good reference to line up with. I’ll go with that plus a little extra.
When priming the oil system - my regular 1/2” drill interferes with the cowl, I’ve been priming with my 3/8” 90* drill, 700 max rpm. I’ve got oil at all the rockers, and fairly quickly at that - less than a minute. The right bank somewhat slower than the left. Some of the lifters “pumped up”, some did not.
Do I need to rotate the engine to get the weight of the valve spring off of the lifter to get them to “pump up”? Or is this to do with pump rpm / system pressure?
Old Dec 27, 2021 | 11:12 AM
T.L.'s Avatar
You just need to establish oil pressure before initial startup. Don't prime it for a long time, because you'll wash a lot of the cam lube off, and you don't want that...
Old Dec 27, 2021 | 05:23 PM
You just need to establish oil pressure before initiwl startup. Don't prime it for a long time, because you'll wash a lot of the cam lube off, and you don't want that...
Okay, good. I don’t have a bunch of time priming, I can still see lube on the cam and lifters through the little ports in the valley.
Tomorrow is the day. Only the accessory drive, cooling system and distributor remains.
Old Dec 28, 2021 | 02:46 PM
Thank you all for your help,
File Type: mov
File Type: mov
84 t/a 5.0
Apr 15, 2007 12:27 PM
Nixon1
Jun 17, 2003 10:29 PM
TZFBird
Mar 19, 2002 08:44 PM
BuddyLeeX
Dec 29, 2001 10:28 AM
Justy
Mar 11, 2001 03:53 AM
