EGR Identification for testing
Old Feb 20, 2022 | 12:38 PM
tbroadfoot125's Avatar
Engine: 87 5.0L TPI
1987 5.0l, TPI. I have the upper part of the engine apart to flush the fuel system, since the car has sat for several years with fuel in the system and not ran. I figured while I have the plenum and intake tubes off, I would pull the fuel rail to flush it out along with checking the injectors. I figured that while I am doing this, it would be a good time to test the EGR valve. I found instructions for checking it but I am not sure if it is a positive pressure or negative pressure EGR. Have yet to find any specs on it online to tell me which one it is. One article I found said that there would be a letter N in the part number if it is negative back pressure. The numbers do have a N but not in the part number just in the 71N which I am not sure what it is. Numbers on at are as following and I attached a picture.
DDW 17087263
182
71N
Thanks in advance for your help.
Steven 86IROC-Z
Jul 21, 2015 06:07 PM
goliath88
Jan 9, 2012 05:24 PM
kallark
Aug 27, 2011 09:03 AM
86z28iroc-z
Nov 13, 2006 09:19 PM
Dave Farr
Jan 9, 2006 02:26 PM
